How Do You Find the Limit of (e^x - 1) / Sin(x) as x Approaches 0?
  • MHB
  • Thread starter FallArk
  • Tags
    Limit
In summary, the problem is to find the limit of $\dfrac{e^x - 1}{\sin x}$ as $x$ approaches $0$, without using L'Hospital's Rule. The solution involves writing the expression as a product and finding the limit of each factor separately. The second factor can be evaluated using the fact that $\lim\limits_{x\to 0} \dfrac{\sin x}{x} = 1$, which can also be used to find the limit of the first factor. Therefore, the limit of the entire expression is 1.
FallArk
127
I'm stuck on this problem: find \(\displaystyle \lim_{{x}\to{0}} \frac{e^{x}-1}{\sin x}\)
Since no L'Hospital's Rule is allowed. I wonder if i can make use of the idea of punctured neighborhood(the current topic we learned in class) . Not sure how to set it up.
Hi FallArk,
Write
$$\frac{e^x - 1}{\sin x} = \frac{e^x - 1}{x} \cdot \frac{x}{\sin x}$$
and find the limit of each factor on the right-hand side.
Euge said:
Hi FallArk,
Write
Aha! that makes sense! since i can use the fact e^x = 1+x + x^2/2! +... and find that the limit is 1, for x/sinx, I am thinking squeeze rule?
I'm sure you've learned about the limit
$$\lim_{x\to 0} \frac{\sin x}{x}$$
in which case the limit of the second factor can be found by computing
$$\frac{1}{\lim\limits_{x\to 0} \dfrac{\sin x}{x}}$$
as $\dfrac{\sin x}{x}$ is the reciprocal of $\dfrac{x}{\sin x}$.
Really, both limits relate to derivatives of two functions at $0$. So there's no need to resort to Taylor series expansions. For example,
$$\lim_{x\to 0} \frac{e^x - 1}{x} = \lim_{x\to 0} \frac{e^x - e^0}{x - 0} = \frac{d}{dx}\bigg|_{x = 0} e^x = 1$$
FAQ: How Do You Find the Limit of (e^x - 1) / Sin(x) as x Approaches 0?
1. What is the limit of e^x-1/sin x as x approaches 0?
The limit of e^x-1/sin x as x approaches 0 is equal to 1. This can be determined by using L'Hopital's rule or by simplifying the expression and plugging in the value of x=0.
2. How do you find the limit of e^x-1/sin x as x approaches infinity?
The limit of e^x-1/sin x as x approaches infinity does not exist. This can be shown by taking the limit of each individual term, which results in infinity for e^x and 0 for sin x.
3. Is the limit of e^x-1/sin x continuous?
No, the limit of e^x-1/sin x is not continuous at x=0. This is because the limit from the left side is equal to 1, while the limit from the right side is equal to infinity.
4. Are there any restrictions on the values of x for which the limit of e^x-1/sin x exists?
Yes, the limit of e^x-1/sin x only exists when x is a real number and not equal to 0 or any multiple of pi. This is because the expression is undefined when the denominator, sin x, is equal to 0.
5. Can you use any other methods to find the limit of e^x-1/sin x?
Yes, other methods such as Taylor series expansion can also be used to find the limit of e^x-1/sin x. However, L'Hopital's rule is typically the most efficient method for this type of limit.
