MHB How Do You Find the MLE of Lambda in a Sum of Two Poisson Distributions?
To find the maximum likelihood estimator (MLE) of lambda (L) in a sum of two Poisson distributions, the parameters are defined as X~Poisson(nL) and Y~Poisson(mL), where m and n are natural numbers. The sum S = aX + bY involves real constants a and b. The key point is that the sum of two independent Poisson variables results in another Poisson variable with a parameter equal to the sum of the individual parameters, specifically (m+n)L. The challenge lies in determining the probability mass function (pmf) for S to compute the MLE effectively. Understanding the properties of Poisson distributions is crucial for solving this problem.
JGalway
First of all I will use L to denote lambda the parameter of the distribution.
X~Poission(nL), n$\in\Bbb{N}$,
Y~Poisson(mL),m$\in\Bbb{N}$ with m$\ne$n
S= aX+bY a,b real constants.
Given observations x and y find the maximum likelihood estimator of L.
The problem is I don't know what the pmf is for S which as far as I know you need to get the MLE.
Thanks in advance for any feedback.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
