How do you identify the systems in which Newton's Third Law is obeyed?
In summary, when working with Newton's Third Law, it's necessary to include the Earth in your system to conserve momentum.
pkc111
225
Ive noticed that in doing a lot of physics questions, identifying the location of the reaction force can be very difficult.
F1,2 = -F2,1
eg. For a ball in free fall (ignoring air resistance) there is only one force acting if the system is just considered to be the ball. It seems necessary to go to the system which includes the Earth for identification of the reaction force to be made. Is there any rule for how big a system must be in order for Newtons Third Law to be obeyed within that system (ie both the action and reaction forces to be identified within it)?
Generally when one speaks of a 'system' in mechanics it means a collection of bodies which will be treated as a unit for some purpose. I.e. we are concerned with forces between systems, not forces within them.
In that sense, Newtons Third Law concerns the force two systems exert on each other.
pkc111 said:
Homework Statement:: I've noticed that in doing a lot of physics questions, identifying the location of the reaction force can be very difficult.
Relevant Equations:: F1,2 = -F2,1
Newton's third law is responsible for the law of conservation of momentum. It's only if you include the Earth in your system that momentum is conserved. Momentum of the falling ball is not conserved.
The question ultimately is whether your system has external forces.
Sure, but how do you know how big to draw your system to capture all action/reaction forces?
You know from the problem statement. A ball is falling under gravity; a charged particle is placed in an electric field; a wagon is accelerating at ##2m/s^2## ... In all these cases, the object (ball, particle, wagon) is being influenced by some external force.
It shouldn't be hard to see when there are external things influencing the motion of the system.
Likes Delta2
You keep adding bodies until you have everything you care about.
E.g. bouncing a ball against a wall, there will be forces between the wall and the floor etc., reaching out to encompass the Earth. But you don't usually care about any of that, so you just treat the wall as having infinite inertial mass.
Likes Delta2
That makes sense. Thank you both.
Likes Delta2
FAQ: How do you identify the systems in which Newton's Third Law is obeyed?
How does Newton's Third Law apply to everyday situations?
Newton's Third Law states that for every action, there is an equal and opposite reaction. This means that whenever an object exerts a force on another object, the second object exerts an equal and opposite force back on the first object. This can be seen in everyday situations such as pushing a door open or bouncing a ball off a wall.
What are some examples of systems where Newton's Third Law is obeyed?
Newton's Third Law applies to all systems where there are interactions between objects. This includes situations such as a rocket launching into space, a person walking on the ground, or a car driving down the road. In each of these cases, there are forces acting in opposite directions that are equal in magnitude.
How do you identify the forces involved in a system to determine if Newton's Third Law is obeyed?
To identify the forces involved in a system, you must first identify all the objects in the system and the interactions between them. Then, you can use Newton's Third Law to determine if the forces are equal and opposite. If they are, then the law is being obeyed in that system.
Can Newton's Third Law be violated?
No, Newton's Third Law is a fundamental law of physics and cannot be violated. In every interaction, there are always equal and opposite forces acting on the objects involved. However, if the forces are not balanced, the objects will experience an acceleration, which can give the illusion that the law is being violated.
How does Newton's Third Law relate to the conservation of momentum?
Newton's Third Law is closely related to the conservation of momentum, which states that the total momentum of a system remains constant in the absence of external forces. This means that in any interaction, the total momentum before and after the interaction must be equal. Since Newton's Third Law ensures that forces are equal and opposite, the momentum of each object will change in opposite directions, resulting in a conservation of momentum.
