How do you integrate a term with a differential?
In summary: Differentials are infinitesimally small values. In the context of an integral, they indicate what the variable of integration is.
Vardaan Bhat
79
In my Halliday Resnick Walker book, they derive the equations of kinematics using integrals in a small section after the algebraic derivation. I'm extremely confused by the calculus, however. Sorry if my questions are unclear.They say that [tex]\frac{dx}{dt}=v⇒dx=v\cdot dt[/tex]. This first step itself confuses me. Are [itex]dx[/itex] and [itex]dy[/itex] supposed to be infinitesmally small values? If so, are they constants? I thought that this is just a notation that shows the derivative of position with respect to time, but is this for a specific time [itex]t[/itex] or does it represent some property that holds for all times?
Second, they integrate each side of [itex]dx=v\cdot dt[/itex], and end up with [itex]\int dx=\int v \: dt[/itex], with [itex]dt[/itex] as the integral term of the RHS. That made no sense to me; how does [itex]dt[/itex] go from being a constant to an integral term simply representing what variable you're integrating with respect to?Again, sorry if my question is unclear.
Thanks in advance!
No and no. dx and dt are differentials.
As already said, neither of these is a constant. Both dx and dt indicate what the variable of integration is.
On the left side, you get x + C1. On the right side, you get vt + C2 (assuming v is a constant).
It's customary to have only one arbitrary constant, so after integration, you would have x = vt + C.
Thanks in advance!
Sorry, I'm still a little confused. I thought a differential is an infinitesmally small value.
Specifically,
Cauchy, following d'Alembert, inverted the logical order of Leibniz and his successors: the derivative itself became the fundamental object, defined as a limit of difference quotients, and the differentials were then defined in terms of it. That is, one was free to define the differential dy by an expression
in which dy and dx are simply new variables taking finite real values, not fixed infinitesimals as they had been for Leibniz.
So how does dy change from being a finite real value to the integral term?
In an integral such as ##\int f(t)dt##, the role dt plays is to indicate what the variable of integration is.
In another context, suppose y = f(t). Then dy = f '(t)dt, by definition. Here dt is an infinitesimal, and the differential of y (dy) is f '(t) times dt.
Okay, but then how does the infinitesmal turn into the term of an integral (how does it turn from a constant into something else)?
In neither case is the differential a constant.
When used in an integral, as in ##\int f(t) dt##, you don't actually multiply anything by dt. To evaluate this integral, you look for a function F such that F' = f. It serves no purpose at all to think of dt in the context of an integral as being a differential.
Likes Vardaan Bhat
But in the differential equation where you multiply by dt, isn't it a differential? How does it magically turn into the integral term?
Sorry, I'm still getting used to all of this weird notation.
Yes, but what I'm saying is that the context is different between the equation involving differentials and an integral expression.
You're fine with ##y = f(t) \Rightarrow \frac{dy}{dt} = f'(t)##, right?
When you're first learning about the derivative in calculus, many textbooks take pains to tell you not to treat ##\frac{dy}{dt}## as a fraction. However, there's no harm in doing so, as the equation above can be rewritten in a way that defines the differential of y as ##dy = f'(t)dt##.
Differentiation if more-or-less the inverse operation of antidifferentiation, so from ##dy = f'(t)dt##, it's an easy step to go to ##\int dy = \int f'(t)dt \Rightarrow y = f(t) + C##
I don't know what more I can say.
Do you know what an "infinitesimally small value" is? That is a rather advanced topic in the foundations of mathematics and, from what you say, you don't appear to be that advanced.
Likes Vardaan Bhat
They aren't values neither fractions but these notations are treated as fractions. Remember Chain Rule? Yup.
Others explained the more advanced stuff already. I'm only a High Schooler..
Sort of. They're numbers so close to 0 that they're virtually the same thing. Essentially it's what happens as [itex]x_1-x_0 \rightarrow 0[/itex]
It can also be expressed as [itex]\frac{1}{\infty}[/itex]
No, there are no such things. In any number system other than those used in "non-standard analysis", [itex]\frac{1}{\infty}= 0[/itex] and there are no "infinitesmals". While it is "convenient" to think of the "dy" and "dx" in dy/dx as separate quantities, and call them "infinitesmals", to prove things with them requires knowing "non-standard analysis", as I said rather an advanced field and certainly not taught in High School. In "standard" Calculus, the derivative, dy/dx, is first defined as a limit, not a fraction, then define the functions of x and y, not numbers, and certainly not "infinitesmals", such that "dy= (dy/dx) dx". I am just saying that you should use the word "differentials", not "infinitesmals".
(When Newton and Leibniz first developed the Calculus, they did it in terms of "infinitesmals" which y were never able to properly define. The Bishop Berkeley famously satirized them as "ghosts of departed quantities". Much later Cauchy and others developed Calculus using the "limit" procedure commonly used today. Abraham Robinson published a paper in 1961 and a textbook in 1966, both titled "non-standard analysis", setting "infinitesmals" on a rigorous logical basis. However, to do so he had to use deep results from symbolic logic, in particular the "compactness property", that "if every finite subset of a set of axioms has a model then so does the entire set." Unless you understand what that means I recommend avoiding that path.)
Well differentials are just extremely small quantities, no? That's what I've been taught. I've been taught differentiation and integration using the standard limit-based method...
It looks to me like you are remembering what you were taught not quite correctly. In Thomas' "Calculus" (the edition revised by Weir et. al.. Thomas, of course, passed away a few years ago. I actually had Thomas as my instructor in my first Calculus class. Yes, I really am that old!) a "differential" is defined by "Let y= f(x) be a differentiable function. The differential dx is an independent variable. The differential dy is dy= f'(x)dx. Notice that neither dx nor dy is a number at all. They are variables.
If we define [tex]f'(x)=\lim_{h\to\ 0}\frac{f(x+h)-f(x)}{h}[/tex] is [itex]h[/itex] the same thing as [itex]dx[/itex] and [itex]f(x+h)-f(x)[/itex] the same thing as [itex]dy[/itex]?
No to both. f(x + h) - f(x) is the same as ##\Delta y##, which is the change in y between the points (x, f(x)) and (x + h, f(x + h)).
No, if that were true you would be saying "[itex]f'(x)= \lim_{h\to 0}\frac{dy}{dx}[/itex]" and that I not true- f'(x) and [itex]\frac{dy}{dx}[/itex] are different ways of writing the same thing. Are you clear on what "[itex]\lim_{h\to 0}[/itex]" means?
x and y are variables on the domain of the function, while dx and dy are variables on tangent space to the domain. thus at a given point x, the value of dx at a tangent vector v is equal to the x component of v. i.e. dx measures how much the tangent line to the graph changes in the direction. but i am celebrating. maybe this is wrong.
Likes protonsarecool
Well, [itex]\lim_{x\to k} f(x)=L[/itex] means that for every [itex]\epsilon[/itex] such that [itex]|f(x)-L|<\epsilon[/itex], there is some [itex]\delta[/itex] such that [itex]0<|x-k|<\delta[/itex]. [itex]\lim_{h\to 0} f(h)=L[/itex] means that as [itex]h[/itex] is getting closer and closer to [itex]0[/itex], [itex]f(h)[/itex] is getting closer and closer to [itex]L[/itex].
Very good! So you realize that saying that [itex]A= \lim_{h\to 0} B(h)[/itex] is NOT the same as "A= B".
Likes Vardaan Bhat
This made absolutely no sense to me...
HallsofIvy said:
Very good! So you realize that saying that [itex] \lim_{h\to 0} B(h)[/itex] is NOT the same as "A= B".
So what's the next step to understanding what a differential is (dx and dy)?
Because I don't understand how they freely multiply by dt and treat dx/dt as a fraction.
It might be worthwhile to work through a calculus textbook alongside HRW so these confusions can be rectified.
Well, I am taking a course on Calculus through the Art of Problem Solving. I'm using their book, but I still don't understand this idea of computing with differentials.
Likes Vardaan Bhat
Their book is absolutely excellent, and their books are some of the most popular among math olympiad contestants and young mathematicians around the world. I do agree that one source is not enough; reading from and using multiple sources is always optimal.
I do, however, already have a lot of backlog from the course, so I'll start going through something more rigorous after it ends.
sorry kid, i may try again tomorrow to explain what a differential is, or you could google how to integrate say a one form.
Related to How do you integrate a term with a differential?
1. How do you integrate a term with a differential?
Integrating a term with a differential involves finding the antiderivative of the term and then evaluating it at the given limits. This can be done using various integration techniques such as substitution, integration by parts, or using integral tables.
2. What is the purpose of integrating a term with a differential?
The purpose of integrating a term with a differential is to find the area under a curve or the accumulation of a quantity over a given interval. It is also used to solve differential equations and model real-world phenomena.
3. What are the different types of differentials that can be integrated?
The most commonly integrated differentials are dx, dy, and dt. However, any variable can be used as a differential as long as it is independent of the other variables in the equation.
4. Can you explain the concept of indefinite and definite integrals?
An indefinite integral is the antiderivative of a function without any specified limits of integration. It is represented by the ∫ symbol and a constant of integration is added at the end. A definite integral, on the other hand, has specified limits of integration and gives a numerical value as the result.
5. What are some tips for solving integrals involving trigonometric functions?
When integrating trigonometric functions, it is helpful to use trigonometric identities, such as the Pythagorean identities, to simplify the expression. It is also important to pay attention to the limits of integration and use the appropriate trigonometric substitution if necessary.
  • Calculus
