How do you know when k in Hooke's law is positive or negativ
In summary, the conversation discusses a problem involving a 7.2-kg mass hanging from a spring in an elevator. The elevator is described as having different accelerations and a specified height. The equations used and the direction of the spring's movement are also mentioned. The correct equation for spring force is clarified.
Derek Marusarz
A 7.2-kg mass is hanging from the ceiling of an elevator by a spring of spring constant 150N/m whose unstretched length is 80 cm. What is the overall length of the spring when the elevator: (a) starts moving upward with acceleration 0.95m/s2 ; (b) moves upward at a steady 14m/s ; (c) comes to a stop while moving upward at 14 m/s , taking 9.0 s to do so? (d) If the elevator measures 3.2 m from floor to ceiling, what is the maximum acceleration it could undergo without the 7.2-kg mass hitting the f loor?
In part (a), the professor used the equation ma = kx - mg, with the solution being 80 + x. I have seen both equations as F = kx and F = -kx. Now, I realize one must analyze every siruation, but there must beva way to resolve which way the spring is moving. Thank you.
Welcome to the PF. :smile:
AFAIK, "k" is always a positive coefficient. Whether the "Force" is "positive" or "negative" depends on the directions of the forces and the directions of the unit vectors in the coordinate systems. Spring force is always restorative to the equilibrium position of the spring when it is neither extended nor compressed. Does that make sense?
Further to berkeman's comments, if you are consistent with regard to signs for the displacement and the force, the correct equation is F=-kx. The other would be better written as |F|=k|x|.
Related to How do you know when k in Hooke's law is positive or negativ
1. How is k determined in Hooke's law?
In Hooke's law, k represents the spring constant and is determined by measuring the force required to stretch or compress a spring by a certain distance. The ratio of force to distance is the value of k.
2. What does a positive value of k indicate in Hooke's law?
A positive value of k indicates that the spring is exerting a force in the opposite direction of its displacement. This means that the spring is trying to return to its original position.
3. How do you know if k is negative in Hooke's law?
If the spring is compressing under an applied force, the value of k will be negative. This means that the spring is exerting a force in the same direction as its displacement.
4. Can the value of k change in Hooke's law?
Yes, the value of k can change if the characteristics of the spring, such as its material or length, are altered. It can also change if the force or displacement changes.
5. Is it possible for k to have a value of 0 in Hooke's law?
Yes, if there is no force applied to the spring, the value of k will be 0. This means that the spring is not exerting any force in either direction and is in a state of equilibrium.
9K
