ducnguyen2000
- 13
I'm just curious on how a near-perfect vacuum is created.
Vanadium 50 said:Pumps. Lots of pumps, of various kinds. Sorry to be so generic, but it's hard to be specific with a question that's so general. Maybe if you would tell us what kind of answer you are looking for we could craft an answer that suits you.
ZapperZ said:A turbo pump costs around... what... $10,000? An ion pump, without the controller, might be a bit cheaper. A cryopump costs around... $30,000 with the compressor. If you have that much money, can I be your friend?
And we haven't even gone into the type of vacuum chamber, valves, flanges, gauges, etc.
Zz.
pixel01 said:For what kind of pumps you should use, you first have to identify how high vacuum you need (E-5, -6 or -9 etc..), and does it have the intake (how much). How big the manifold is also very important.
ducnguyen2000 said:Well... I want a vacuum for a cathode ray experiment, and it's about a foot long and 3 inches in radius.
Creating a near-perfect vacuum involves removing all air particles from a defined space. This can be achieved through various methods such as using a vacuum pump, freezing the air particles, or using chemical reactions to absorb the air.
A near-perfect vacuum is often used in scientific experiments and industrial processes to remove any interference from air particles. It is also used in the production of electronic components and in space simulations.
The level of vacuum is measured using a vacuum gauge, which can measure the pressure inside the vacuum chamber. The most common unit of measurement for vacuum is torr, which represents the pressure exerted by a column of mercury.
No, it is not possible to achieve a completely perfect vacuum. Even in outer space, there are still a few particles per cubic meter. The best vacuum that can be achieved on Earth is around 10^-15 torr.
Working with a near-perfect vacuum can be dangerous as sudden changes in pressure can cause implosions or explosions. It is important to use proper safety precautions and equipment when working with a vacuum, such as wearing protective gear and following proper protocols for handling and releasing the vacuum.
