How do you multiply percents on paper
  • B
  • Thread starter jim1174
  • Tags
    Paper
In summary, to multiply percents on paper, it is best to rewrite the numbers in powers of ten and factor out the powers of ten to add or subtract exponents. When multiplying by hand, it is important to remember that % means divided by 100 and to count the number of decimal places in the numbers being multiplied to determine the placement of the decimal point in the answer.
jim1174
79
5 million times 5 percent would be 5000000 X 0.05. When you do this on a calculator you get 250000 but when you do it on paper you end up with more zeros in the answer. When you multiply percents on paper what is the easiest way to figure out how many zeros go in your answer?
Mathematics news on Phys.org
When it comes to computing math by hand, I like fractions more than decimals.
5 percent is 5/100, so I'd multiply 5 million by 5 to get 25 million, and divide by 100 to get 250 thousand.
If you're getting more zeroes, you may be getting 25000000, but because it's 0.05 instead of 5, you need to shift the decimal point in your result two places to the left.
First and most important is that % means nothing else than divided by 100.
Next it is best to write such numbers by powers of ten: ##5000000=5,000,000 = 5\cdot 10^6##. Thus we have
5000000 \cdot 0.05 = 5 \cdot 10^6 \cdot 5 \cdot \frac{1}{100} = 25 \cdot 10^6 \cdot 10^{-2} =25 \cdot10^4 = 250,000
Likes Imager and FactChecker
Factor out the powers of 10 (move the decimal point) so that you can add or subtract exponents: ##5000000 * 0.05 = 5*10^6*5*10^{-2} = 25*10^{6-2} = 25*10^4 = 250000.##
EDIT: I'm too slow. ;>)
It is a rule of decimal long hand multiplication. Count all the places to the right of the decimal point in both numbers, in your case 2 places(0.05) and 0 int the original number. the answer has to a decimal point 2 places to the left.
example: 0.125 x 1.34 = 125 x 134 = 16750 now we need to add 5 decimal places: 0.16750 or 0.15675
Related to How do you multiply percents on paper
1. How do you multiply a percent by a whole number?
To multiply a percent by a whole number, first convert the percent to a decimal by moving the decimal point two places to the left. Then, multiply the decimal by the whole number as you normally would.
2. How do you multiply two percents together?
To multiply two percents together, first convert each percent to a decimal. Then, multiply the decimals together as you normally would. Finally, convert the decimal answer back to a percent by moving the decimal point two places to the right.
3. Can you multiply a percent by a fraction?
Yes, you can multiply a percent by a fraction. First, convert the percent to a decimal by moving the decimal point two places to the left. Then, multiply the decimal by the fraction's numerator. Finally, divide the product by the fraction's denominator and convert the decimal answer back to a percent.
4. What is the shortcut for multiplying percents on paper?
The shortcut for multiplying percents on paper is to first convert the percents to decimals, then multiply the decimals together and finally convert the decimal answer back to a percent.
5. How do you multiply a percent by a negative number?
To multiply a percent by a negative number, first convert the percent to a decimal by moving the decimal point two places to the left. Then, multiply the decimal by the negative number as you normally would. The resulting answer will also be negative. Finally, convert the answer back to a percent by moving the decimal point two places to the right.
  • General Discussion
  • STEM Academic Advising
