MHB How do you prove that a function is bijective?
  • Thread starter Thread starter Guest2
    Function
To prove that the function f: (0, ∞) → (0, ∞) defined by f(x) = x^2 is bijective, it is first established as injective by showing that if f(a) = f(b), then a must equal b. For surjectivity, it is necessary to demonstrate that for every y in (0, ∞), there exists an x in (0, ∞) such that y = x^2, which can be achieved by defining a right-inverse function g(x) = √x. This approach emphasizes the importance of the function's domain and co-domain in determining its properties. The discussion also highlights how changing these parameters can affect the function's injectivity and surjectivity. Understanding these concepts is essential for proving a function's bijectiveness.
Guest2
Suppose I want to prove that the function $f: (0, \infty) \to (0, \infty)$ defined by $f(x) = x^2$ is bijective.
Let $a, b \in (0, \infty)$ and $f(a) = f(b)$. Then $a^2 = b^2 \implies a = b$ since everything is non-negative we can simply take square roots. Therefore $f$ is injective. To prove that $f$ is surjective, let $y \in (0, \infty)$. How do I prove that there's $x \in (0, \infty)$ such that $y=x^2$?
Mathematics news on Phys.org
I believe that follows from the definition of the function.
One way to prove a function $f:A \to B$ is surjective, is to define a function $g:B \to A$ such that $f\circ g = 1_B$, that is, show $f$ has a right-inverse.
Equivalently, we must show for all $b \in B$, that $f(g(b)) = b$. Beware! This does NOT mean that $g(f(a)) = a$, in fact this is usually untrue (unless $f$ is injective).
In this case, we may take $g(x) = \sqrt{x}$, which works BECAUSE OF THE DOMAINS of $f$ and $g$ (non-negative reals).
Investigate which (injectivity or surjectivity, or both) fails if we change the domain, or co-domain, like so:
$f: \Bbb R \to [0,\infty)$ given by $f(x) = x^2$
$f: \Bbb R \to \Bbb R$ given by $f(x) = x^2$.
Perhaps this will persuade you that the properties of a function do not depend just on its "rule of computation".
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
