How do you prove that a=-(w^2)
  • Thread starter asdf1
The determinant method can be extended to higher dimensions using the wedge product and exterior algebra, but it becomes more complicated and abstract.
asdf1
734
how do you prove that a=-(w^2)
from v=wxr?
i know you're supposed to differentiate v=wxr, but i don't know how to differentiate a cross product...
The cross product is the vector created by the determinant
[tex] a \times b =
\begin{tabular}{|c c c|}
i & j & k \\
a_1 & a_2 & a_3 \\
b_1 & b_2 & b_3 \\
\end{tabular}
[/tex]
So, take the determinant of the above matrix, and then differentiate as normal. (Hint: the determinant will give you a vector, with 3 coordinates. You can differentiate each coordinate on its own.)
Edit: are you familiar with how to take a determinant? Otherwise you can use [itex]a \times b = |a||b|\sin{\theta}[/itex], but then you'll have to know [itex]\theta[/itex], or treat it as a constant.
wow!
thank you very much!
what happens if you want to prove it for an infinite number of coordinates(ex., i, j, k, l, m, ...)?
asdf1 said:
wow!
The cross product is only defined in R3.
FAQ: How do you prove that a=-(w^2)
What is the equation "a=-(w^2)" stating?
The equation is stating that "a" is equal to the negative value of "w" squared.
How do you prove that "a=-(w^2)"?
To prove this equation, you would need to use algebraic manipulations to rearrange the equation and show that both sides are equal. This could involve distributing the negative sign, combining like terms, and using the properties of exponents.
Is there a specific method or formula for proving "a=-(w^2)"?
There is no specific method or formula for proving this equation. It will depend on the specific problem and what algebraic manipulations are needed to show that both sides are equal.
What are some common mistakes to avoid when proving "a=-(w^2)"?
Some common mistakes to avoid include forgetting to distribute the negative sign, making errors when combining like terms, and incorrectly applying the properties of exponents.
Can you explain the concept of "a=-(w^2)" in simpler terms?
This equation is essentially stating that the value of "a" is equal to the negative value of "w" squared. It is a way to represent a relationship between two variables using algebraic notation.
