How Do You Prove the Formula for n Choose k?
  • MHB
  • Thread starter wittysoup
In summary, the formula for n choose k is n!/(k!(n-k)!) and the induction hypothesis is that $P_k$ which can be proved using Pascal's identity.
wittysoup
Hello all,
I need a little help with how to go about proving the following:
For this, I have proceeded as follows:
Base case P(j):
I am not sure if this is correct... but the next step would be to Assume P(k), I get stuck at that step because the algebraic expression does not look right... Am I going about this the right way? Thanks.
Your base case $P_j$ would be:
$\displaystyle \sum_{i=j}^j{i \choose j}={j \choose j}=1={j+1 \choose j+1}$
This is true.
Next, state the induction hypothesis $P_k$:
$\displaystyle \sum_{i=j}^k{i \choose j}={k+1 \choose j+1}$
I think my inductive step would be to add ${k+1 \choose j}$ to both sides:
$\displaystyle \sum_{i=j}^k{i \choose j}+{k+1 \choose j}={k+1 \choose j+1}+{k+1 \choose j}$
$\displaystyle \sum_{i=j}^{k+1}{i \choose j}={k+1 \choose j+1}+{k+1 \choose j}$
Now, what you need to do is show that:
$\displaystyle {k+1 \choose j+1}+{k+1 \choose j}={(k+1)+1 \choose j+1}$
Essentially, you need to prove Pascal's identity. Use the definition of the binomial coefficients to do so, and if you get stuck, we can offer further guidance.
Thanks for that, it seems like I miscalculated the first result... I am now stuck here, being that I do not know how to simplify this ( I actually worked out further on paper trying to get a common denominator)...
I would state:
$\displaystyle {k+1 \choose j+1}+{k+1 \choose j}=\frac{(k+1)!}{(j+1)!((k+1)-(j+1))!}+\frac{(k+1)!}{j!((k+1)-j)!}$
Simplify a bit:
$\displaystyle {k+1 \choose j+1}+{k+1 \choose j}=\frac{(k+1)!}{(j+1)!(k-j)!}+\frac{(k+1)!}{j!(k+1-j)!}$
Next, factor:
$\displaystyle {k+1 \choose j+1}+{k+1 \choose j}=\frac{(k+1)!}{j!(k-j)!}\left(\frac{1}{j+1}+\frac{1}{k+1-j} \right)$
Combine terms within parentheses:
$\displaystyle {k+1 \choose j+1}+{k+1 \choose j}=\frac{(k+1)!}{j!(k-j)!}\left(\frac{k+1-j+j+1}{(j+1)(k+1-j)} \right)$
Combine like terms:
$\displaystyle {k+1 \choose j+1}+{k+1 \choose j}=\frac{(k+1)!}{j!(k-j)!}\left(\frac{k+2}{(j+1)(k+1-j)} \right)$
Combine factors:
$\displaystyle {k+1 \choose j+1}+{k+1 \choose j}=\frac{(k+2)!}{(j+1)!(k+1-j)!}$
Rewrite right side as binomial coefficient:
Thus, using this result in our inductive step, we obtain:
$\displaystyle \sum_{i=j}^{k+1}{i \choose j}={(k+1)+1 \choose j+1}$
We have derived $P_{k+1}$ from $P_k$ thereby completing the proof by induction.
Hello,
Thank you for reaching out for help with proving the formula for n choose k. Your approach so far is on the right track, but there are a few things that can be improved.
First, let's define what n choose k means. It represents the number of ways to choose k objects from a set of n objects, without regard to the order in which they are chosen. So, for example, if we have a set of 5 objects and we want to choose 3 of them, n choose k would give us the number of possible combinations of 3 objects from the set of 5.
With that in mind, let's start with the base case P(j). This should be the simplest case where n choose k is easy to calculate. In this case, we can choose all n objects from the set, which means n choose n = 1. This is because there is only one way to choose all n objects - by choosing all of them.
Next, we can move on to the inductive step, where we assume P(k) and try to prove P(k+1). This means we are assuming that the formula holds for choosing k objects from a set of n objects, and we want to show that it also holds for choosing k+1 objects from a set of n+1 objects.
To do this, we can use the fact that n choose k can also be written as n choose (n-k). This is because choosing k objects from a set of n is the same as choosing n-k objects to not be included in the chosen set. So, we can rewrite the formula as n choose (n-k) = n!/(k!(n-k)!).
Next, we can use the definition of n choose k to expand the left side of the equation. This gives us (n+1) choose (k+1) = (n+1)!/((k+1)!(n+1-k)!).
Now, we can use the inductive hypothesis that P(k) is true, which means n choose k = n!/(k!(n-k)!). We can substitute this into our expanded equation, giving us (n+1)!/((k+1)!(n+1-k)!) = (n!/(k!(n-k)!))*(n+1)/((k+1)(n+1-k)).
From here, we can simplify the expression by cancelling out common terms and rearranging
FAQ: How Do You Prove the Formula for n Choose k?
What is "n Choose k" and why is it important in mathematics?
"n Choose k" is a mathematical formula used to determine the number of combinations that can be made when choosing k objects from a set of n objects. It is important in mathematics because it has many applications in probability, statistics, and combinatorics.
How do you prove the formula for n Choose k?
There are a few different ways to prove the formula for n Choose k, but one common method is using mathematical induction. This involves proving the formula for a base case (usually n = 0 or 1) and then using a series of logical steps to show that the formula holds for all values of n.
Can you provide an example of using n Choose k in real life?
One example of using n Choose k in real life is when selecting a group of people to serve on a committee. If there are n people to choose from and the committee needs to have k members, then the number of different combinations of members can be calculated using n Choose k.
What are some common mistakes when using n Choose k?
One common mistake when using n Choose k is forgetting to take into account the order in which the objects are chosen. n Choose k only counts the number of combinations, not permutations, so the order in which the objects are selected does not matter. Another mistake is using the formula for n Choose k when dealing with a situation that involves replacements, as the formula only applies to combinations without replacement.
Are there any shortcuts for calculating n Choose k?
There are a few shortcuts for calculating n Choose k, such as using Pascal's Triangle or the binomial coefficient formula. These methods can be helpful for larger values of n and k, but ultimately it is important to understand the underlying concept and how to apply it in order to accurately calculate n Choose k.
