How Do You Prove This Integral Equals \(\frac{\pi}{2}\ln \pi\)?
  • MHB
  • Thread starter Chris L T521
In summary, the integral $\displaystyle \int_0^{\infty} \frac{\arctan(\pi x) - \arctan x}{x}\,dx$ represents the difference between two inverse tangent functions and is a special case of a more general integral. Its value can be derived using techniques from complex analysis, and it has a close relationship with the natural logarithm function. While other methods can be used to evaluate the integral, they may not yield a closed form solution. The integral has applications in various areas of mathematics and physics and is connected to other fields such as number theory and complex analysis.
Chris L T521
MHB
915
Thanks again to those who participated in last week's POTW! Here's this week's problem!
Problem: Show that $\displaystyle \int_0^{\infty} \frac{\arctan(\pi x) - \arctan x}{x}\,dx = \frac{\pi}{2}\ln \pi$.
Hint: [sp]First express the integral as an iterated integral. Then reverse the order of integration and evaluate.[/sp]
This week's problem was correctly answered by MarkFL. You can find his solution below.
[sp]We are given to demonstrate:
\(\displaystyle I=\int_0^{\infty} \frac{\tan^{-1}(\pi x) - \tan^{-1}(x)}{x}\,dx = \frac{\pi}{2}\ln(\pi)\)
Expressing the integral as an iterated integral, we have:
\(\displaystyle I=\int_0^{\infty}\int_x^{\pi x}\frac{1}{y^2+1}\,dy\,\frac{1}{x}\,dx\)
The region of integration is:
\(\displaystyle 0\le x\le\infty\)
\(\displaystyle x\le y\le\pi x\)
Which can also be described by:
\(\displaystyle \frac{y}{\pi}\le x\le y\)
\(\displaystyle 0\le y\le\infty\)
Hence, changing the order of integration gives us:
\(\displaystyle I=\int_0^{\infty}\frac{1}{y^2+1}\int_{\frac{y}{\pi}}^{y}\frac{1}{x}\,dx\,dy\)
Applying the FTOC to the inner integral, we find:
\(\displaystyle I=\int_0^{\infty}\frac{1}{y^2+1}\left[\ln|x| \right]_{\frac{y}{\pi}}^{y}\,dy\)
\(\displaystyle I=\int_0^{\infty}\frac{1}{y^2+1}\left(\ln(y)-\ln\left(\frac{y}{\pi} \right) \right)\,dy\)
\(\displaystyle I=\ln(\pi)\int_0^{\infty}\frac{1}{y^2+1}\,dy\)
Applying the FTOC to the outer integral gives us:
\(\displaystyle I=\ln(\pi)\left[\tan^{-1}(y) \right]_0^{\infty}\)
Since \(\displaystyle \tan^{-1}(0)=0\) and \(\displaystyle \lim_{t\to\infty}\tan^{-1}(y)=\frac{\pi}{2}\) there results:
\(\displaystyle I=\frac{\pi}{2}\ln(\pi)\)
Shown as desired.[/sp]
Here's my solution as well (an alternate to Mark's):
[sp]Note that we can rewrite the given integral as the following iterated integral:
\[\int_0^{\infty}\frac{\arctan(\pi x) - \arctan x}{x}\,dx = \int_0^{\infty}\int_1^{\pi} \frac{1}{1+(xy)^2}\,dy\,dx\]
and since the region we're integrating over is an infinite rectangle where $0\leq x < \infty$, $1\leq y\leq \pi$, reversing the order of integration is very simplistic and leaves us with
\[\begin{aligned}\int_1^{\pi}\int_0^{\infty} \frac{1}{1+(xy)^2}\,dx\,dy &= \int_1^{\pi}\left.\left[\frac{\arctan(xy)}{y}\right]\right|_0^{\infty}\,dy \\ &= \int_1^{\pi} \frac{1}{y}\left[ \lim_{b\to\infty} \arctan(bx) - \arctan(0)\right]\,dy \\ &= \frac{\pi}{2}\int_1^{\pi}\frac{1}{y}\,dy \\ &= \frac{\pi}{2}\left.\left[\ln|y|\right]\right|_1^{\pi}\\ &= \frac{\pi}{2}\left[\ln \pi - \ln 1\right] \\ &= \frac{\pi}{2}\ln\pi\end{aligned}\][/sp]
FAQ: How Do You Prove This Integral Equals \(\frac{\pi}{2}\ln \pi\)?
What is the significance of the integral $\displaystyle \int_0^{\infty} \frac{\arctan(\pi x) - \arctan x}{x}\,dx$?
The integral represents the difference between two inverse tangent functions, one with a coefficient of $\pi$ and one without. It is a special case of the more general integral $\displaystyle \int_0^{\infty} \frac{f(\pi x) - f(x)}{x}\,dx$, which has been extensively studied in mathematics and physics.
How is the value of $\displaystyle \int_0^{\infty} \frac{\arctan(\pi x) - \arctan x}{x}\,dx$ derived?
The value of the integral can be derived using techniques from complex analysis, specifically the Residue Theorem. By analyzing the behavior of the integrand as a complex function, we can determine the value of the integral using contour integration.
What is the relationship between the integral and the natural logarithm function?
The integral is closely related to the natural logarithm function, as shown by the fact that the value of the integral is equal to $\frac{\pi}{2}$ multiplied by the natural logarithm of $\pi$. This relationship has interesting implications in the study of transcendental numbers and the properties of the logarithm function.
Can the integral be evaluated using other methods besides complex analysis?
Yes, the integral can also be evaluated using other techniques such as integration by parts, substitution, and series expansions. However, these methods may not yield a closed form solution and may require numerical approximation methods.
What are the applications of the integral $\displaystyle \int_0^{\infty} \frac{\arctan(\pi x) - \arctan x}{x}\,dx$?
The integral has applications in various areas of mathematics and physics, including the study of special functions, Fourier series, and the behavior of certain physical systems. It also has connections to other areas such as number theory and complex analysis.
