How do you rewrite this equation in standard form?
In summary: F(x,y)= C$ we have... $\displaystyle F(x,y)= \int \frac{\mu_{x}}{\mu}\ dx + \int \frac{y\ \mu_{y}}{\mu}\ dy = C\ (4)$... and as $\displaystyle y\ \mu_{y} = -
find_the_fun
148
\(\displaystyle y dx-4(x+y^6)dy=0\)
so is it legal to add \(\displaystyle 4(x+y^6)dy\) to both sides of the equation? I thought it's bad to add integrands (i.e. dx or dy).
Or is it legal to divide both sides of the equation by dx? Would this result in
\(\displaystyle y-4(x+y^6)\frac{dy}{dx}=0\) or \(\displaystyle y-\frac{4(x+y^6)}{dx}\frac{dy}{dx}=0\)
The given ODE is already written in differential form. To solve it, you need to determine if it is exact, and if not, to compute an integrating factor to make it exact.
I don't think that there is really a "standard" form to these. But typically they are written in both formats.
One problem: You have too many "dx"s in that last equation. The first form on that line is correct.
-Dan
I'm still stuck. I'm getting the wrong answer.
\(\displaystyle ydx-4(x+y^6)dy=0\)
\(\displaystyle \frac{dy}{dx}-\frac{y}{4(x+y^6)}=0\) (1)
therefore \(\displaystyle P(x)=\frac{-1}{4(x+y^6)}\)
let \(\displaystyle \mu = e^{\int P(x) dx} = e^{\frac{-1}{4(x+y^6)}}dx = e^{\ln{|(x+y^6)^{\frac{1}{4}}|}}+C\) choose \(\displaystyle C=0\)
multiply both sides of (1) by integrating factor
\(\displaystyle \frac{dy}{dx} \frac{1}{(x+y^6)^{\frac{1}{4}}}-\frac{y}{4(x+y^6)} \frac{1}{(x+y^6)^{\frac{1}{4}}}=0\)
\(\displaystyle \frac{d}{dx}[\mu(x)y]=\frac{d}{dx}(x+y^6)^{\frac{-1}{4}}y=0\)
\(\displaystyle \int \frac{d}{dx}[(x+y^6)^{\frac{-1}{4}}y]dx = \int 0 dx\)
\(\displaystyle \frac{(x+y^6)^{-3}}{-3}+C=\frac{-1}{3(x+y^6)^3}+C\)
from this equation I can solve for y and get \(\displaystyle y=\sqrt[3]{\frac{-1}{3C}-x}\) and solving for x gives \(\displaystyle x=\frac{-1-3Cy^3}{3C}\)
The back of book gives
\(\displaystyle x=2y^6+cy^4\)
First of all I don't get that answer. Second, why do they solve for x and not y?
You cannot treat this equation as linear, since we cannot write in the form:
\(\displaystyle \frac{dy}{dx}+P(x)y=Q(x)\)
We can however, use an integrating factor to get an equivalent exact equation.
We are given:
\(\displaystyle y\,dx-4\left(x+y^6 \right)\,dy=0\)
We see that:
\(\displaystyle \frac{\partial}{\partial y}(y)=1\)
\(\displaystyle \frac{\partial}{\partial x}\left(-4\left(x+y^6 \right) \right)=-4\)
Thus, the equation is inexact. So we consider:
\(\displaystyle \frac{\frac{\partial}{\partial x}\left(-4\left(x+y^6 \right) \right)-\frac{\partial}{\partial y}(y)}{y}=-\frac{5}{y}\)
So our integrating factor is:
\(\displaystyle \mu(y)=e^{\int -\frac{5}{y}\,dy}=y^{-5}\)
And thus our ODE becomes (observing that we are eliminating the trivial solution $y\equiv0$):
\(\displaystyle y^{-4}\,dx-4\left(xy^{-5}+y \right)\,dy=0\)
And we can easily see that this equation is exact. We know that the solution must therefore be given implicitly by:
\(\displaystyle F(x,y)=C\)
And because the equation is exact, we know:
\(\displaystyle \frac{\partial F}{\partial x}=y^{-4}\)
\(\displaystyle \frac{\partial F}{\partial y}=-4\left(xy^{-5}+y \right)\)
And so we take:
Now, what you need to do to get the solution is:
(a) Integrate this with respect to $x$, where the constant of integration is a function of $y$:
\(\displaystyle F(x,y)=\int y^{-4}\,dx+g(y)\)
(b) Then to determine $g(y)$, take the partials of both sides and then solve for $g'(y)$.
(c) Integrate $g'(y)$, omitting the constant of integration (as the implicit solution already contains an arbitrary constant).
(d) Replace $g(y)$ in the implicit solution you found in part(a).
Solving this for $x$ will give you an explicit solution (the one given by your textbook).
Sorry I don't follow. I rewrote the equation \(\displaystyle \frac{dy}{dx} - \frac{y}{4(x+y^6)} = 0\) which is in the form and \(\displaystyle P(x)=\frac{-1}{4(x+y^6)}\) and \(\displaystyle Q(x)=0\) so isn't this equation in linear form?
Your function $P$ is a function of both $x$ and $y$. So the ODE is non-linear. :D
We are given:
We see that:
And so we take:
The procedure You used to find an integrating factor is very interesting and I want to realize if I have understood correctly. A differential expression like $\displaystyle A(x,y)\ dx + B(x,y)\ dy$ is 'exact' if $\displaystyle A_{y} (x,y) = B_{x} (x,y)$. In the OP is $\displaystyle A(x,y)= y$ and $B(x,y)= - 4\ (x + y^{6})$ so that the differential expression isn't exact. The idea is to make it exact by multiplying A and B by an unknown function $\displaystyle \mu(x,y)$ so that is exact the expression...
$\displaystyle A(x,y)\ \mu(x,y)\ dx + B (x,y)\ \mu (x,y)\ dy\ (1)$
... and that conducts to the PDE...
$\displaystyle A_{y} \ \mu + A\ \mu_{y} = B_{x}\ \mu + B\ \mu_{x} \implies \mu + y\ \mu_{y} = - 4\ \mu - 4\ (x+y^{6})\ \mu_{x}\ (2)$
The (2) seems not very comfortable, but if we suppose that $\mu$ is function of the y alone [i.e. $\displaystyle \mu_{x}=0$...] the (2) becomes the ODE...
$\displaystyle y\ \mu^{\ '} = -5\ \mu\ (3)$
... one solution of which is $\displaystyle \mu(y) = \frac{1}{y^{5}}$ that the integrating factor we searched...
It that 'all right'?...
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
Hello chisigma,
It looks like you have the gist of it quite well. :D
I will paraphrase from my old ODE textbook (Fundamentals of Differential Equations, 3rd Edition, by Nagle/Saff), the following information regarding integrating factors of inexact equations...
If the equation:
(1) \(\displaystyle M(x,y)dx+N(x,y)dy=0\)
is not exact, but the equation:
(2) \(\displaystyle \mu(x,y)M(x,y)dx+\mu(x,y)N(x,y)dy=0\)
which results from multiplying equation (1) by the function $\mu(x,y)$, is exact, then $\mu(x,y)$ is called an integrating factor of the equation (1).
How do we find an integrating factor? If $\mu(x,y)$ is an integrating factor of (1) with continuous first partial derivatives, then testing (2) for exactness, we must have:
\(\displaystyle \frac{\partial}{\partial y}\left(\mu(x,y)M(x,y) \right)=\frac{\partial}{\partial x}\left(\mu(x,y)N(x,y) \right)\)
By use of the product rule, this reduces to the equation:
(3) \(\displaystyle M\frac{\partial \mu}{\partial y}-N\frac{\partial \mu}{\partial x}=\left(\frac{\partial N}{\partial x}-\frac{\partial M}{\partial y} \right)\mu\)
But solving the partial differential equation (3) for $\mu$ is usually more difficult than solving the original equation (1). There are, however, two important exceptions.
Let's assume equation (1) has an integrating factor that depends only on $x$, that is, $\mu=\mu(x)$. In this case, equation (3) reduces to the separable equation:
(4) \(\displaystyle \frac{d\mu}{dx}=\left(\frac{\frac{\partial M}{\partial y}-\frac{\partial N}{\partial x}}{N} \right)\mu\)
where \(\displaystyle \frac{\frac{\partial M}{\partial y}-\frac{\partial N}{\partial x}}{N}\) is just a function of $x$.
In a similar fashion, if equation (1) has an integrating factor that depends only on $y$, then equation (3) reduces to the separable equation:
(5) \(\displaystyle \frac{d\mu}{dx}=\left(\frac{\frac{\partial N}{\partial x}-\frac{\partial M}{\partial y}}{M} \right)\mu\)
where \(\displaystyle \frac{\frac{\partial N}{\partial x}-\frac{\partial M}{\partial y}}{M}\) is just a function of $y$.
We can solve these separable equations (4) and (5) to obtain for (1) the integrating factors:
If \(\displaystyle \frac{\frac{\partial M}{\partial y}-\frac{\partial N}{\partial x}}{N}\) is continuous and depends only on $x$, then:
(6) \(\displaystyle \mu(x)=\exp\left(\int\left(\frac{\frac{\partial M}{\partial y}-\frac{\partial N}{\partial x}}{N} \right)\,dx \right)\)
is an integrating factor for (1).
If \(\displaystyle \frac{\frac{\partial N}{\partial x}-\frac{\partial M}{\partial y}}{M}\) is continuous and depends only on $y$, then:
(7) \(\displaystyle \mu(y)=\exp\left(\int\left(\frac{\frac{\partial N}{\partial x}-\frac{\partial M}{\partial y}}{M} \right)\,dy \right)\)
There are many differential equations that are not covered by this method, but for which an integrating factor nevertheless exists. The major difficulty, however, is in finding an explicit formula for these integrating factors, which in general will depend on both $x$ and $y$.
FAQ: How do you rewrite this equation in standard form?
What does it mean to write an equation in standard form?
Writing an equation in standard form means to rearrange the terms so that the equation follows the format ax + by = c, where a, b, and c are constants and x and y are variables.
Why is it important to rewrite an equation in standard form?
Rewriting an equation in standard form can make it easier to graph and compare with other equations. It also helps to identify the slope and y-intercept of the equation.
How do you determine the coefficients in an equation written in standard form?
The coefficients in an equation written in standard form are the numbers in front of the variables x and y. They can be identified by looking at the equation in the form ax + by = c.
Can any equation be written in standard form?
Yes, any linear equation can be rewritten in standard form. However, equations with fractions may need to be multiplied by a common denominator to eliminate the fractions before rearranging.
What is the process for rewriting an equation in standard form?
The process for rewriting an equation in standard form involves rearranging the terms so that the equation follows the format ax + by = c. This may involve combining like terms, moving terms to the other side of the equation, or multiplying by a common denominator to eliminate fractions.
