How do you sketch (x^2-5)^2+y^2=16 without a calculator or software?
In summary, the conversation discusses different methods for sketching a circle with a radius of 4 units and a center at (5,0). The use of parametric equations and transforming the x^2 axis to the xy axis are suggested as possible approaches. The idea of using a compass or string to draw the circle is also mentioned. There is a mention of finding symmetries and using them to determine specific x-coordinates of points.
GravitySK
curve sketching
calculus
Someone told me to use parametric equations to find symmetries first
but are there other methods to sketch this graph?
How do you think
Take x^2 axis and y axis. The figure is the circle centered at (5,0) with radius 4. Then it is easy to transform it to x-y axes.
Likes OmCheeto and GravitySK
Yeah that's interesting
actually I don't know how to transform x^2 y-axis to xy axis...
x^2=1 corresponds x=-1,1
x^2=9 corresponds x=-3,3
x^2=5 corresponds x=-sqrt5, sqrt5, etc.
You then got six (x,y) points.
Edit: not six, eight (x,y) points
got it thanks
Likes HallsofIvy
GravitySK said:
got it thanks
Can we see?
Likes OmCheeto
Now that you know that the circle is centered at (5,0) and has radius 4 units, to sketch it without a calculator or software, get a cheap compass, spread it to a distance of 4 units, put the pointy end at (5,0) units and draw the circle. You can also do it with a nail, some string and a pencil.
You also easily get x co-ordinates of four points where y = 0, and symmetry tells you something about their special nature.
Related to How do you sketch (x^2-5)^2+y^2=16 without a calculator or software?
1. What is the equation for a circle?
The equation for a circle in standard form is (x-h)^2 + (y-k)^2 = r^2, where (h,k) represents the center of the circle and r is the radius.
2. How do you sketch a circle without a calculator or software?
To sketch a circle without a calculator or software, first identify the center and radius of the circle from the given equation. Then, use a compass to draw the circle, making sure the distance between the compass point and pencil tip is equal to the radius. Finally, use a ruler to draw any necessary lines or curves.
3. What is the equation for a circle with a center at the origin?
The equation for a circle with a center at the origin is x^2 + y^2 = r^2, where r is the radius of the circle.
4. How do you sketch a circle with a center at the origin without a calculator or software?
To sketch a circle with a center at the origin without a calculator or software, follow the same steps as sketching a circle with a given center and radius. However, in this case, the center is at (0,0) so you do not need to draw any additional lines or curves.
5. What is the equation for a circle with a given center and radius?
The equation for a circle with a given center (h,k) and radius r is (x-h)^2 + (y-k)^2 = r^2.
