How Do You Solve a Projectile Motion Problem?
In summary: One for before firing and one for after firing. Can you please clarify which equation is for before firing?B.)Determine the total time t in the air.t = 2*V*sin 45.2/g = 2*43.6*0.71/9.806 = 6.314 sec
blackcemre
A projectile is fired with an initial speed of 46.6 m/s at an angle of 42.2 ∘ above the horizontal on a long flat firing range.
1-Determine the maximum height reached by the projectile.
2-Determine the total time in the air.
3-Determine the total horizontal distance covered (that is, the range).
4-Determine the speed of the projectile 1.50 s after firing.
5-Determine the direction of the motion of the projectile 1.50 s after firing.
v = vo +at x = xo + vot + .5at2 v2 = vo2 + 2a(x - xo) x=vt
A.) Determine the maximum height Ymax reached by the projectile.
Ymax = (V*sin 45.2)^2/2g = (43.6*0.71)^2/19.612 = 48.86 mB.)Determine the total time t in the air.
t = 2*V*sin 45.2/g = 2*43.6*0.71/9.806 = 6.314 secC.)Determine the total horizontal distance covered (that is, the range).
Δx = V*cos 45.2*t = 43.6*0.705*6.314 = 194.08 m
So what's the question? You couldn't do #4 and #5?
Zz.
The numbers you've used in your work do not match those stated in the problem statement. Which numbers are correct?
There is confusion about the symbols used.
Is V the initial speed?
In the relevan equations, there are two different equations for x.
Related to How Do You Solve a Projectile Motion Problem?
1. What is projectile motion?
Projectile motion is the motion of an object that is launched or thrown into the air and moves along a curved path under the influence of gravity.
2. What factors affect the trajectory of a projectile?
The trajectory of a projectile is affected by the initial velocity, the angle of launch, and the force of gravity.
3. How is the range of a projectile calculated?
The range of a projectile is calculated using the formula R = (V^2 * sin(2θ))/g, where V is the initial velocity, θ is the angle of launch, and g is the acceleration due to gravity.
4. Can a projectile have a curved trajectory?
Yes, a projectile can have a curved trajectory if there is an external force acting on it, such as air resistance or wind.
5. What is the maximum height reached by a projectile?
The maximum height reached by a projectile is calculated using the formula H = (V^2 * sin^2(θ))/(2g), where V is the initial velocity and θ is the angle of launch. This is the point at which the vertical component of the projectile's velocity becomes zero.
21K
