How Do You Solve Basic Kinematics Problems?
In summary, the conversation is about a person asking for help with kinematics equations for their upcoming midterm. They need help with problems involving distance, velocity, and acceleration, and may have a list of equations to refer to. The expert advises them to look at what values are given and what they want to find, and to pay attention to units. They also suggest breaking down projectile motion problems into separate parts and using free body diagrams to analyze forces. Finally, the expert helps them solve a problem and offers tips for approaching different types of questions.
amd123
110
Please help with Kinematics HAVE MID TERM TOMRROW :(!
I have a mid term tomorrow and I'm in a dire situation. I don't remember how to do kinematics equations like
A bus leaves the terminal and travels for 900s at an average velocity of 10 m/s before it stops at its first destination. How far from the terminal is the first destination?
The cars on a ride travel at a constant velocity of 4 m/s on a circular track that has radius of 4 m. What is the magnitude of centripetal acceleration?
A car traveling at 91 km/h approaches turn off for a restaurant 30 m ahead. If the driver slams onto the brakes with an acceleration of -6.40m/s^2 what will her stopping distance be?
Can someone please explain to me the basics and how to do these problems?
Are you permitted to have a list of kinematic equations? If so, things will be much easier.
A good way to approach these questions is to look at what values are given and what you want to find. This often will put you on the right track, even if you're not sure exactly how to get there. If you have a list of equations, try to select one that lists only one unknown variable.
For your first example, you are given a time (in seconds) and a velocity (in meters/second). You are then asked to find a distance. How would you go from (seconds) and (meters/second) to get an answer with units of distance only?
For your second example, you need to know the equation for centripetal acceleration (this happens to be a = v2/R).
For the third example, list all of your known variables and your unknown, paying close attention to units.
I hope this helps.
yes we get a list of equations
We have not even discussed the 2nd question type so I was really confused and could you solve number 1 for me?
I also have projectile motion problems and ones that involve sin cos tan functions. I can do those but i needed to review the basic ones from earlier year
For the first example, think about it this way:
You want distance (meters). You have time (seconds) and velocity (meters/second). To find an answer that involves only meters, you multiply time by velocity:
(seconds) x (meters/second) = (meters)
Once you reach this point, you only need to substitute in the given values.
I'm not sure how much help I can give you with the 2nd type of question if you haven't covered that material. The best I can recommend is to find the equations relating to it and to try your best in applying them to a given problem. Focusing on the units may help in this case.
For projectile motion, I generally find the best approach for me is to look at each portion of the motion separately (vertical motion upwards, vertical motion downwards, horizontal motion).
Lastly, remember to always draw a free body diagram when you are looking at forces acting on an object. It will clear things up in almost every case.
so its 9000 m?
That's correct.
FAQ: How Do You Solve Basic Kinematics Problems?
What is Kinematics?
Kinematics is the branch of physics that studies the motion of objects without considering the forces that cause the motion. It involves analyzing the position, velocity, and acceleration of an object in relation to time.
How is Kinematics different from Dynamics?
Kinematics focuses on the description of motion, while dynamics focuses on the causes of motion. Kinematics uses mathematical equations to analyze the motion of objects, while dynamics uses Newton's laws of motion to explain why objects move as they do.
What topics are typically covered in a Kinematics course?
A Kinematics course will typically cover topics such as displacement, velocity, acceleration, projectile motion, circular motion, and relative motion. It may also include topics such as linear and angular momentum, work and energy, and rotational motion.
How can I prepare for a Kinematics midterm?
To prepare for a Kinematics midterm, it is important to review all of the key concepts and equations covered in class. Practice solving problems and make sure you understand the steps and reasoning behind each solution. It may also be helpful to create study guides or flashcards to aid in memorizing important equations and concepts.
What are some real-world applications of Kinematics?
Kinematics has many real-world applications, such as designing roller coasters, analyzing sports movements, and understanding the motion of planets and satellites. It is also used in engineering to design machines and structures that involve moving parts, such as cars and bridges.
10K
