How Do You Solve for k in a Logarithmic Function with a Given Inverse?
But yes, it does save a few steps! So in summary, the function f(x) is defined as k\ log_2 x and the value of k can be found by using the inverse function, f^{-1}(x), which can be rewritten as 2^{\frac{x}{k}}. Using the given value of f^{-1}(1)=8, we can solve for k and find that k=\frac{1}{3}. Then, to find the value of f^{-1}\left(\frac{2}{3} \right), we can either use the approach of setting f(x) equal to \frac{2}{3} and solving for x, or we can use the fact that f^{-1}(
karush
MHB
3,269
Let \(\displaystyle f(x) = k\ log_2 x\)
(a) Given that \(\displaystyle f^{-1}(1)=8\), find the value of \(\displaystyle k\)
to get \(\displaystyle f^{-1}(x)\) exchange \(\displaystyle x\) and \(\displaystyle y\)
\(\displaystyle x=log_2 y^k\)
then convert to exponential form
\(\displaystyle 2^x=y^k \) then \(\displaystyle 2^{\frac{x}{k}} = y\)
so for \(\displaystyle f^{-1}(1) = 2^{\frac{1}{k}}= 8=2^3\) then \(\displaystyle \frac{1}{k}=3\) so \(\displaystyle k=\frac{1}{3}\)
(b) find \(\displaystyle f^{-1}\bigg(\frac{2}{3}\bigg)=2^{\frac{2}{3}\frac{3}{1}}=2^2=4\)
Mathematics news on Phys.org
Re: inverse log and find k
a) Another approach would be to use that:
\(\displaystyle f^{-1}(1)=8\implies f(8)=1\)
and so:
\(\displaystyle f(8)=f\left(2^3 \right)=k\log_2\left(2^3 \right)=3k=1\,\therefore\,k=\frac{1}{3}\)
b) We could write:
\(\displaystyle f^{-1}\left(\frac{2}{3} \right)=x\)
\(\displaystyle f(x)=\frac{2}{3}\)
\(\displaystyle \frac{1}{3}\log_2(x)=\frac{2}{3}\)
\(\displaystyle \log_2(x)=2\)
\(\displaystyle x=2^2=4\)
Hence:
\(\displaystyle f^{-1}\left(\frac{2}{3} \right)=4\)
well that was a better idea...:cool:
I wouldn't say better, just different. :D
(c) The inverse of a logarithmic function is an exponential function. In this case, the inverse of f(x) is given by f^{-1}(x)=2^{\frac{x}{k}}. This means that for any input value x, the output of the inverse function will be the value of the exponent that, when raised to the base 2, will give the input value x. In other words, the inverse function "undoes" the action of the original function.
To find the value of k, we can use the fact that f^{-1}(1)=8. Plugging this into the inverse function, we get 2^{\frac{1}{k}}=8. Solving for k, we get k=\frac{1}{3}. This means that the inverse function is f^{-1}(x)=2^{\frac{x}{3}}.
To find the inverse of a specific input value, we can plug it into our inverse function. For example, to find f^{-1}\bigg(\frac{2}{3}\bigg), we plug \frac{2}{3} into our inverse function and get 2^{\frac{2}{3}\frac{3}{1}}=2^2=4. So the inverse of \frac{2}{3} is 4.
In conclusion, the inverse logarithm function is an exponential function, and the value of k can be found by setting f^{-1}(1) equal to a known value and solving for k. The inverse function can then be used to find the inverse of any input value.
FAQ: How Do You Solve for k in a Logarithmic Function with a Given Inverse?
What is an inverse logarithm?
An inverse logarithm is the opposite operation of a logarithm. While a logarithm solves for the exponent when given a base and a number, an inverse logarithm solves for the number when given a base and an exponent.
How do you calculate an inverse logarithm?
To calculate an inverse logarithm, you can use the formula y = bx, where b is the base and x is the exponent. Simply plug in the given values for b and x and solve for y.
What is the purpose of finding the inverse logarithm?
The purpose of finding the inverse logarithm is to solve for the original number when given its logarithm. Inverse logarithms are often used in exponential growth and decay problems, as well as in data analysis and modeling.
What is the value of k in inverse logarithm equations?
The value of k in inverse logarithm equations represents the base of the logarithm. This value is typically a constant and is used to help solve for the original number when given its logarithm.
What are some real-world applications of inverse logarithms?
Inverse logarithms have many real-world applications, including in finance, biology, and physics. They are used to model population growth and decay, calculate interest rates, and measure the acidity of a substance on the pH scale.
