How Do You Solve POTW #287 Involving Integer Equations?
  • MHB
  • Thread starter anemone
  • Tags
    2017
In summary, the solution to POTW #287 for November 13th, 2017 is not a specific answer, as the POTW is a weekly problem that changes every week. However, the process for solving any POTW problem is the same and involves several steps. These steps include carefully reading and understanding the problem, identifying relevant concepts and formulas, making a plan for solving the problem, solving it using the chosen method or formula, checking the answer, and finding alternative solutions if time permits. It is allowed to use calculators and other tools, but all steps and work must be shown. The time it takes to solve a POTW problem varies and collaboration with others is not allowed.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Positive integers $a,\,b, \,c, \,d$, and $e$ satisfy the equations
$(a + 1)(3bc + 1) = d + 3e + 1\\
(b + 1)(3ca + 1) = 3d + e + 13\\
(c + 1)(3ab + 1) = 4(26 − d − e) − 1$
Evaluate $d^2 + e^2$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to castor28 for his solution(Smile), which you can find below:
Let us write $P$, $Q$, $R$ for the left hand side of the equations. Adding the three equations gives:
$P + Q + R = 117 \qquad(*) $
The last equation shows that $R = (c+1)(3ab+1)$ is odd. This shows that both factors are odd, and $c$ and at least one of $\{a,b\}$ are even.
Because $c$ is even, the first two equations give the congruences modulo 2:
\begin{align*}
a+1 &\equiv d + e + 1 \pmod{2}\\
b + 1&\equiv d + e + 1 \pmod{2}
\end{align*}
from which we conclude that $a\equiv b\pmod{2}$. Because of the previous remark, $a$, $b$, and $c$ are all even; in particular they are greater than or equal to $2$.
If we take $a=b=c=2$, we get $P=Q=R=39$ and $P+Q+R = 117$, which is the correct value. Since this is the smallest possible solution, and, as all the coefficients are positive, any other solution would make $P+Q+R$ greater, this is the only solution of $(*)$.
With these values, we get a linear system:
\begin{align*}
\qquad d + 3e + 1&=39\\
3d + e + 13&=39
\end{align*}
giving $d=5$, $e=11$, and $d^2+e^2=146$.
Alternative solution:
By expanding the three given equations and adding them all up we have
$9abc+3ab+3bc+3ca+a+b+c+3=117$
Multiply both sides of the equation above by 3 and rearranging the constant and finally factor the resultant equation gives
$27abc+9ab+9bc+9ca+3a+3b+3c+1=343$
This is equivalent to
$(3a+1)(3b+1)(3c+1)=7^3$
Since $a,\,b$ and $c$ are positive integers, this implies $a=b=c=2$ and therefore $d=5$ and $e=11$.
Hence, $d^2 + e^2=5^2+11^2=146$
FAQ: How Do You Solve POTW #287 Involving Integer Equations?
What is the solution to POTW #287 for November 13th, 2017?
The solution to POTW #287 for November 13th, 2017 is not a specific answer, as the POTW (Problem of the Week) is a weekly problem that changes every week. However, the process for solving any POTW problem is the same, and can be broken down into several steps.
What are the steps for solving a POTW problem?
The steps for solving a POTW problem are as follows:
1. Read the problem carefully, making sure to understand all the given information and what is being asked.
2. Identify the relevant concepts and formulas that may be used to solve the problem.
3. Make a plan for how to approach the problem, which may include breaking it down into smaller parts or using diagrams.
4. Solve the problem using the chosen method or formula.
5. Check your answer and make sure it makes sense in the context of the problem.
6. If you have time, try to find alternative methods or solutions to the problem.
Can I use a calculator or other tools to solve a POTW problem?
Yes, you can use a calculator or other tools to solve a POTW problem. However, it is important to show all steps and work to receive full credit for your solution. Also, some POTW problems may specifically state whether or not certain tools or aids are allowed, so be sure to read the instructions carefully.
How long does it typically take to solve a POTW problem?
The time it takes to solve a POTW problem varies depending on the difficulty of the problem and the individual's level of understanding and familiarity with the concepts being tested. Some may be able to solve a problem quickly, while others may need more time to think through and solve the problem. However, it is important to not rush and to show all steps and work to receive full credit.
Can I collaborate with others to solve a POTW problem?
No, it is not allowed to collaborate with others when solving a POTW problem. The purpose of the POTW is to test individual understanding and problem-solving skills, and working with others would defeat this purpose. It is important to solve the problem on your own and to show your own work to receive full credit.
