MHB How Do You Solve the Equation \(\sqrt{x+8} + 2 = \sqrt{x}\) in Complex Numbers?
  • Thread starter Thread starter Amer
    Complex
The equation \(\sqrt{x+8} + 2 = \sqrt{x}\) has been analyzed for complex solutions, revealing a contradiction when assuming a complex solution exists. By expressing the square roots in polar form and equating their components, it leads to the conclusion that \(2=0\), indicating no solutions exist in the complex domain. However, an alternative perspective suggests that if the negative square root is considered, \(x=1\) emerges as a valid solution through the double squaring method. This highlights the importance of the approach taken when solving square root equations. Ultimately, the discussion underscores the complexities involved in solving such equations in different number systems.
Amer
how to solve this equation in complex
Thanks
Re: Complex solve a equation
Thanks
Hi Amer, :)
Suppose that a complex solution exists for this equation. Let,
\[\sqrt{x+8}=r_1 e^{i\theta_1}\mbox{ and }\sqrt{x}=r_2 e^{i\theta_2}\]
Then by \(\sqrt{x+8} + 2 = \sqrt{x}\) we get,
\[r_1\cos\theta_1+2=r_2\cos\theta_2~~~~~~~~~~~(1)\]
and,
\[r_1\sin\theta_1=r_2\sin\theta_2~~~~~~~~~~~(2)\]
Also,
\[\Rightarrow r^{2}_2 e^{2i\theta_2}+8=r^{2}_1 e^{2i\theta_1}\]
\[\Rightarrow r^{2}_1\sin2\theta_1=r^{2}_2\sin2\theta_2\]
\[\Rightarrow r^{2}_1\sin\theta_1\cos\theta_1=r^{2}_2\sin\theta_2\cos\theta_2~~~~~~~~~~~(3)\]
By (2) and (3),
\[r_1\cos\theta_1=r_2\cos\theta_2~~~~~~~~~~~(4)\]
Therefore by (1) and (4),
\[2=0\]
which is a contradiction. Hence there exist no solutions for the equation,
\[\sqrt{x+8} + 2 = \sqrt{x}\]
Wolfram verifies this. :)
Kind Regards,
Sudharaka.
Thanks
It is fully evident that x=1 [which is a complex number with imaginary part equal to zero...] is solution of the equation if one takes the negative square root in both terms. This solution can easily be found writing the equation as... $\displaystyle \sqrt{x+8} - \sqrt{x} = -2$ (1)... and the applying the standard 'double squaring' procedure... Kind regards $\chi$ $\sigma$
We all know the definition of n-dimensional topological manifold uses open sets and homeomorphisms onto the image as open set in ##\mathbb R^n##. It should be possible to reformulate the definition of n-dimensional topological manifold using closed sets on the manifold's topology and on ##\mathbb R^n## ? I'm positive for this. Perhaps the definition of smooth manifold would be problematic, though.
  • · Replies 18 ·
  • · Replies 31 ·
