How Do You Solve the Equation \(x^3(x+1) = 2(x+a)(x+2a)\) for Real \(a\)?
  • MHB
  • Thread starter anemone
In summary, the purpose of this problem is to practice solving polynomial equations with a real parameter and to understand the concept of setting a variable equal to a given value and solving for the value of the other variable. To solve the equation, you can expand both sides using the distributive property, combine like terms, and use factoring or the quadratic formula. It is possible to solve the equation without knowing the value of a, as it will be determined by the solutions of the equation. Any real value can be used for a, but it is recommended to use a specific value for a specific solution for x. To check your solution, substitute the value of x into the original equation and solve for both sides. If it satisfies the equation, it
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Solve the equation $x^3(x+1)=2(x+a)(x+2a)$ where $a$ is a real parameter.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to Opalg for his correct solution(Cool), which you can find below:
If $x^3(x+1) = 2(x+a)(x+2a)$ then $x^4 + x^3 - 2x^2 - 6ax - 4a^2 = 0$. That factorises as $$x^4 + x^3 - 2x^2 - 6ax - 4a^2 = (x^2-x-2a)(x^2+2x + 2a) = 0.$$ If $x^2-x-a = 0$ then $x = \frac12\bigl(1\pm\sqrt{1+8a}\bigr).$ If $x^2+2x + 2a = 0$ then $x = -1\pm\sqrt{1-2a}$.
Trade secret: where did the factorisation $x^4 + x^3 - 2x^2 - 6ax - 4a^2 = (x^2-x-2a)(x^2+2x + 2a)$ come from?
[sp]Replace the parameter $a$ by $y$, and get Desmos to graph the curve $x^4 + x^3 - 2x^2 - 6xy - 4y^2 = 0$:
[DESMOS]advanced: {"version":7,"graph":{"squareAxes":false,"viewport":{"xmin":-5,"ymin":-5,"xmax":5,"ymax":5}},"expressions":{"list":[{"type":"expression","id":"graph1","color":"#2d70b3","latex":"x^4+x^3-2x^2-6xy-4y^2=0"}]}}[/DESMOS]
This clearly splits into two separate parabolas, which both go through the origin. The upwards-opening parabola has its vertex at $\bigl(\frac12,-\frac18\bigr)$. The downwards-opening parabola has its vertex at $\bigl(-1,\frac12\bigr)$. From that it is easy to find that the first parabola has equation $y = \frac12\bigl(x-\frac12\bigr)^2-\frac18$, or $x^2 - x - 2y = 0$. And the second parabola has equation $y = -\frac12(x+1)^2 + \frac12$, or $x^2 + 2x + 2y = 0.$ Therefore $$x^4 + x^3 - 2x^2 - 6xy - 4y^2 = (x^2 - x - 2y)(x^2 + 2x + 2y).$$ Now replace $y$ by $a$ to get the required factorisation.[/sp]
FAQ: How Do You Solve the Equation \(x^3(x+1) = 2(x+a)(x+2a)\) for Real \(a\)?
What is the equation for POTW #384?
The equation for POTW #384 is x^3(x+1)=2(x+a)(x+2a) with the real parameter a.
What is the goal of solving this equation?
The goal of solving this equation is to find the value of x that satisfies the equation for any given value of the parameter a.
What is the first step in solving this equation?
The first step in solving this equation is to expand the terms on both sides of the equation and simplify to get a cubic equation in x.
How do you solve a cubic equation?
A cubic equation can be solved by using the rational root theorem, finding the roots using the quadratic formula, or using synthetic division and the remainder theorem.
What is the final solution for this equation?
The final solution for this equation is the value of x in terms of the parameter a, which can be obtained by substituting the values of a and the roots of the cubic equation into the original equation.
