How do you solve the integral of 1 over (a+cos(theta)^2) from 0 to 2pi for a>1?
  • Thread starter Thread starter Chris L T521
The integral of 1 over (a + cos(θ)^2) from 0 to 2π for a > 1 can be evaluated to show that ∫_0^(2π) (dθ / (a + cos(θ))^2) equals (2πa) / (a^2 - 1)^(3/2). Sudharaka provided the correct solution to this problem. The evaluation involves techniques from calculus, specifically integration and trigonometric identities. The result highlights the relationship between the integral and the parameters involved, particularly for values of a greater than one. This integral is significant in various applications, including physics and engineering.
Chris L T521
MHB
Here's this week's problem.
Problem: For $a>1$, show that\[\int_0^{2\pi}\frac{\,d\theta}{(a+\cos\theta)^2} = \frac{2\pi a}{(a^2-1)^{3/2}}.\]
Hint:
Use the substitution $z=\exp(i\theta)$ to rewrite the definite integral as a contour integral over the unit circle $|z|=1$.
This week's question was correctly answered by Sudharaka.
Here's my solution:
Let $z=e^{i\theta}$. Then $\cos\theta=\tfrac{1}{2}(z+z^{-1})$ and $\,dz=ie^{i\theta}\,d\theta$. Therefore, the integral becomes
\[\int_{|z|=1}\frac{\,dz}{iz\left(a+\frac{1}{2}(z+1/z)\right)^2} = \int_{|z|=1} \frac{-4iz\,dz}{(z^2+2az+1)^2}.\]
Thus, $f(z)$ has two poles of order $2$ at $z=-a-\sqrt{a^2-1}$ and $z=-a+\sqrt{a^2-1}$. Clearly, $-a-\sqrt{a^2-1}$ is not inside the unit circle, so we can disregard it. However, note that $a\leq 1+\sqrt{a^2-1}$ (due to the triangle inequality), which implies that
\[a-\sqrt{a^2-1}\leq 1 \implies -a+\sqrt{a^2-1}\geq-1.\]
So $-a+\sqrt{a^2-1}$ is contained in the unit circle and now the residue at that point is
\[\begin{aligned}\text{res}_{-a+\sqrt{a^2-1}}f(z) &= \lim_{z\to-a+\sqrt{a^2-1}}\frac{\,d}{\,dz}\left[\frac{-4iz}{(z+a+\sqrt{a^2-1})^2}\right]\\ &=\lim_{z\to-a+\sqrt{a^2-1}}\frac{-4i(z+a+\sqrt{a^2-1})^2+8iz(z+a+\sqrt{a^2-1})}{(z+a+\sqrt{a^2-1})^4}\\ &=\lim_{z\to-a+\sqrt{a^2-1}}\frac{-4i(z+a+\sqrt{a^2-1})+8iz}{(z+a+\sqrt{a^2-1})^3}\\ &=\frac{-4i(2\sqrt{a^2-1})+8i(-a+\sqrt{a^2-1})}{(2\sqrt{a^2-1})^3}\\&=\frac{-ia}{(a^2-1)^{3/2}}\end{aligned}\]
Therefore,
\[\int_0^{2\pi}\frac{\,d\theta}{(a+\cos\theta)^2}= \int_{|z|=1}\frac{-4iz}{(z^2+2az+1)^2} = 2\pi i\left(\frac{-ia}{(a^2-1)^{3/2}}\right) = \frac{2\pi a}{(a^2-1)^{3/2}}\]
Here's Sudharaka's solution:
Substitute \(z=\exp(i\theta)\) and we get,
\begin{eqnarray}
\int_0^{2\pi}\frac{\,d\theta}{(a+\cos\theta)^2} &=& \frac{4}{i}\int_{C}\frac{z}{\left[z-(\sqrt{a^2-1}-a)\right]^{2}\left[z+\sqrt{a^2-1}+a\right]^{2}}\mbox{ where }C\mbox{ is the contour }|z|=1\\
&=& \frac{4}{i}\int_{C}\frac{f(z)}{\left[z-(\sqrt{a^2-1}-a)\right]^{2}}\mbox{ where }f(z)=\frac{z}{\left[z+\sqrt{a^2-1}+a\right]^{2}}\\\end{eqnarray}
It could be shown that, \(|\sqrt{a^2-1}-a|<1\) and therefore the point \(\sqrt{a^2-1}-a\) lie within the contour \(|z|=1\). Using Cauchy's integral formula we get,
\begin{eqnarray}
\int_0^{2\pi}\frac{\,d\theta}{(a+\cos\theta)^2}&=&\frac{4}{i}\left[2\pi i f'\left(\sqrt{a^2-1}-a\right)\right]\\
&=&8\pi \left[\frac{(z+a+\sqrt{a^2-1})^2-2z(z+a+\sqrt{a^2-1})}{(z+a+\sqrt{a^2-1})^4}\right]_{z=\sqrt{a^2-1}-a}\\
\end{eqnarray}
Simplifying this we get,
\[\int_0^{2\pi}\frac{\,d\theta}{(a+\cos\theta)^2} = \frac{2\pi a}{(a^2-1)^{3/2}}\]
  • · Replies 19 ·
