How Do You Solve the Integral of 3x/(4x-1)?
In summary: A=\frac{3}{4}\left(x+\frac{1}{4}\ln|4x-1|\right)+A-\frac{3}{16}\]In summary, the individual is trying to solve the integral of the function 3x/(4x-1), but is stuck. They ask for help and are given the partial fraction decomposition of \(\frac{4x}{4x-1}\).
Yankel
395
Hello
I am trying to solve the integral of the function:
3x/(4x-1)
Need some help with it, I am stuck...
Thanks !
Yankel said:
Hello
3x/(4x-1)
Thanks !
\(\displaystyle \displaystyle \begin{align*} \int{\frac{3x}{4x-1}\,dx} &= \frac{3}{4}\int{\frac{4x}{4x-1}\,dx} \\ &= \frac{3}{4}\int{\frac{4x-1 + 1}{4x - 1}\,dx} \\ &= \frac{3}{4}\int{1 + \frac{1}{4x-1}\,dx} \\ &= \frac{3}{4} \left( x + \frac{1}{4}\ln{ | 4x - 1 | } \right) + C \end{align*}\)
did you use partial fraction here?
letting u = 4x-1, u+1/4 = x
getting the derivative of u, du = 4dx, dx = 1du/4
now plug those values
∫{[3(u+1)/4]/4u]}du
∫[(3u+3)/16u]du
3/16(∫du+∫1/u*du)
3/16*u+3/16*ln|u|+c
3/16*(4x-1)+3/16*ln|4x-1| --- this is what i get when i use substitution method. am I correct?
Yes, it can be thought of as a partial fraction decomposition of \(\frac{4x}{4x-1}\). An easy method to find the partial fractions in this case is the technique used by Prove It; writing the numerator as \(4x-1+1\).
∫{[3(u+1)/4]/4u]}du
∫[(3u+3)/16u]du
3/16(∫du+∫1/u*du)
3/16*u+3/16*ln|u|+c
Yes, your method is perfect. Note that after a few algebraic simplifications you arrive at the same result obtained by Prove It. :)
\[\frac{3}{16}(4x-1)+\frac{3}{16}\ln|4x-1|+C=\frac{3}{4}\left(x+\frac{1}{4}\ln|4x-1|\right)+C-\frac{3}{16}\]
\(A=C-\frac{3}{16}\) is an arbitrary constant. Therefore,
\[\frac{3}{16}(4x-1)+\frac{3}{16}\ln|4x-1|+C=\frac{3}{4}\left(x+\frac{1}{4}\ln|4x-1|\right)+A\]
What I would have done, equivalent to what Prove It and Sudharaka did, is let u= 4x- 1, the denominator. Then 4x= u+ 1 and x= (u+1)/4 and du= 4dx so that dx= (1/4)du.
The integral becomes
[tex]\int \frac{3\frac{u+1}{4}}{u}(du/4)[/tex][tex]= \frac{3}{16}\int \frac{u+1}{u}du[/tex][tex]= \frac{3}{16}\int 1+ \frac{1}{u}du[/tex]
FAQ: How Do You Solve the Integral of 3x/(4x-1)?
What is the integral of 3x/(4x-1)?
The integral of 3x/(4x-1) is 3/4ln|4x-1| + C.
How do you solve the integral of 3x/(4x-1)?
To solve the integral of 3x/(4x-1), you can use the method of partial fractions or integration by substitution. Both methods will result in the same answer.
Can the integral of 3x/(4x-1) be simplified?
Yes, the integral of 3x/(4x-1) can be simplified to 3/4ln|4x-1| + C. However, this is already the simplest form of the integral.
How do you check if the integral of 3x/(4x-1) is correct?
You can check the integral of 3x/(4x-1) by differentiating the result. If the derivative is equal to the original function, then the integral is correct.
Can the integral of 3x/(4x-1) be evaluated at specific values?
Yes, the integral of 3x/(4x-1) can be evaluated at specific values by substituting the given values into the integral. This will give you a specific numerical answer.
