Sudo
- 4
Rockets are propelled by the momentum of the exhaust gases expelled from the tail. Since these gases arise from the reaction of the fuels carried in the rocket, the mass of the rocket is not constant, but decreases as the fuel is expended. Show that for a Rocket starting initially from rest, and taking the velocity of the exhaust gases relative to the rocket, ##v'## = 2.1 m/s and a rate of mass loss per second L = 1/60 of the initial mass, to reach the escape velocity of the Earth (##v_e## = 11.2 km/s), the ratio of the weight of the fuel to the weight of the rocket must be almost 300!
I know that ##F=m(\frac {dp} {dt})=ma=m\frac {dv} {dt}##
First, I work in the frame of the rocket; so we have two forces, the weight ##W=mg## and the force of the exhaust exiting the rocket ##\frac {dm} {dt}v'##. Both forces are pointing downward, thus I set up the following equation: $$ma=m\frac {dv} {dt}=-v'(\frac {dm} {dt})-mg$$ Now I rewrite ##m\frac {dv} {dt}## as ##m\frac {dv} {dm}\frac {dm} {dt}##; now I have this expression:$$m\frac {dv} {dm}\frac {dm} {dt}=-v'(\frac {dm} {dt})-mg$$As ##\frac {dm} {dt}=L=-\frac {m_0} {60}## and dividing both sides by ##m## we have:$$\frac {dv} {dm}(-\frac {m_0} {60})=-\frac {v'} {m}(-\frac {m_0} {60})-g$$Dividing both sides by ##L## yields:$$\frac {dv} {dm}=-\frac {v'} {m}+\frac {60g} {m_0}$$Now we're ready to write our differential equation as follows:$$dv=-\frac {v'} {m}~dm+\frac {60g} {m_0}~dm$$We can now integrate, this knowing that we start from ##v_0=0## and from a certain initial mass given by ##m_0=m_{rocket}+m_{fuel}## and a final mass ##m_f=m_{rocket}##$$\int_0^v dv=-v'\int_{m_0}^{m_f} \frac {1} {m} \ dm+\frac {60g} {m_0}\int_{m_0}^{m_f} dm$$After integrating and evaluating I get the following expression:$$v=-v'ln(\frac {m_f} {m_0})+\frac {60g} {m_0}(m_f-m_0)$$This can be rewritten as:$$v=-v'ln(\frac {m_{rocket}} {m_{rocket}+m_{fuel}})-\frac {60g} {m_{rocket}+m_{fuel}}(m_{fuel})$$Then, if ##m_{fuel}>>m_{rocket}## we can ignore the term ##m_{rocket}## in ##\frac {1} {m_{rocket}+m_{fuel}}##, and the expression can be rewritten as:$$v=-v'ln(\frac {m_{rocket}} {m_{fuel}})-60g=v'ln(\frac {m_{fuel}} {m_{rocket}})-60g$$Solving for the desired ratio I get:$$\frac {m_{fuel}} {m_{rocket}}=e^{\frac {v+60g} {v'}}$$However when plugging in the equation the values ##v'=2.1 m/s##, ##v=11.2 km/s##, and ##g## the value is much, much bigger than 300.
What did I did wrong? Did I chooses the incorrect frame? To my understanding my equation ##ma=m\frac {dv} {dt}=-v'(\frac {dm} {dt})-mg## should be true for this frame, thus ##v'## indeed is 2.1 m/s
Thank you for your time! As always I appreciate detailed answers, thanks again!
