How Do You Solve the System Involving $a$ and $b$ in POTW #202?
  • MHB
  • Thread starter anemone
  • Tags
    2016
In summary, solving a system of equations involves identifying variables, using algebraic manipulation and substitution to eliminate them, and repeating until all variables are solved for. The purpose of solving a system of equations is to find values that satisfy all equations simultaneously. A system of equations has a solution if the equations are consistent and independent, but it can have more than one solution or no solution. There are various methods and techniques that can be used to solve systems of equations.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Find all real numbers for $a$ and $b$ that satisfy the system of equations below:
\(\displaystyle \frac{1}{a}+\frac{1}{2b}=(a^2+3b^2)(3a^2+b^2)\)
\(\displaystyle \frac{1}{a}-\frac{1}{2b}=2(b^4-a^4)\)
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
No one answered last week's problem. :(
You can find the proposed solution below:
We're given the system
Adding the equations gives
\(\displaystyle \frac{2}{a}=a^4+10a^2b^2+5b^4\)---(1)
Subtracting the equations gives
\(\displaystyle \frac{1}{b}=5a^4+10a^2b^2+b^4\)---(2)
Now, multiply the equation (1) by $a$ and get:
\(\displaystyle 2=a^5+10a^3b^2+5ab^4\)---(3)
Next, we multiply the equation (2) by $b$ and get:
\(\displaystyle 1=5a^4b+10a^2b^3+b^5\)---(4)
Adding and subtracting the equations (3) and (4) yield
\(\displaystyle 3=a^5+5a^4b+10a^3b^2+10a^2b^3+5ab^4+b^5=(a+b)^5\)
\(\displaystyle 1=a^5-5a^4b+10a^3b^2-10a^2b^3+5ab^4-b^5=(a-b)^5\)
Solving both last two equations for $a$ and $b$ we get
\(\displaystyle \left(a,\,b\right)=\left(\frac{1+\sqrt[5]{3}}{2},\,\frac{\sqrt[5]{3}-1}{2}\right)\)
FAQ: How Do You Solve the System Involving $a$ and $b$ in POTW #202?
How do I solve a system of equations?
To solve a system of equations, you need to first identify the variables in the equations. Then, use algebraic manipulation and substitution to eliminate one variable and solve for the other. Repeat this process until all variables have been solved for.
What is the purpose of solving a system of equations?
Solving a system of equations allows you to find the values of multiple variables that satisfy all of the equations simultaneously. This is useful in many scientific and mathematical applications, such as finding the intersection point of two lines or determining the concentrations of different substances in a chemical reaction.
How do I know if a system of equations has a solution?
A system of equations has a solution if the equations are consistent and independent. This means that the equations do not contradict each other and there is a unique set of values that satisfy all of the equations. Graphically, this can be represented by the intersection point(s) of the equations on a coordinate plane.
Can a system of equations have more than one solution?
Yes, a system of equations can have more than one solution. This typically occurs when there are more variables than equations, leading to an infinite number of possible combinations of values that satisfy the equations. In some cases, a system of equations may also have no solution if the equations are inconsistent or contradictory.
Are there any shortcuts or tricks for solving systems of equations?
There are various methods for solving systems of equations, such as substitution, elimination, and graphing. In some cases, certain equations may be easier to solve using a specific method. It can also be helpful to rearrange equations or combine them to eliminate variables and make the problem more manageable. Practicing and familiarizing yourself with different methods can also make the process more efficient.
