MHB How Do You Solve This Complex Quadratic Equation?
To solve the complex quadratic equation $\frac{x^2+2}{x}+\frac{8x}{x^2+2}=6$, the discussion suggests simplifying it to $x^4-6x^3+12x^2+12x+4=0$. By substituting $y = \frac{x^2+2}{x}$, the equation transforms into $y + \frac{8}{y} = 6$, which can be solved as a quadratic in y. This approach allows for finding y first, and subsequently determining the values of x. The overall consensus is that the problem can be tackled without exceeding quadratic complexity.
paulmdrdo1
please help me with this
this is where I can get to when I simplify the the equation above,
Mathematics news on Phys.org
the above has become more complex
in case you put
$\frac{x^2+2}{x}= y$
then you get
$ y +\frac{8}{y} = 6$
you get quadratic in y then solve for y and based on it solve for x
I hope you can proceed because at no stage you get more than quadratic
Let $ y = \frac{x^2+2}{x} $
Solve it for y
$y + \frac{8}{y} = 6 $
Then solve it for x
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
