How Do You Solve This Specific Quadratic Equation?
In summary, a quadratic equation is an equation of the form ax^2 + bx + c = 0 with a, b, and c as constants and x as the variable. To solve a quadratic equation, you can use the quadratic formula, factor the equation, or complete the square. There are three types of solutions for a quadratic equation: two real solutions, one real solution, or two complex solutions, which depend on the discriminant, b^2 - 4ac. Quadratic equations are important in science as they are used to model real-world phenomena and solve problems in various fields.
anemone
MHB
POTW Director
3,883
115
Solve \(\displaystyle (m-2)x^2-(m+3)x-2m-1=0\).
Mathematics news on Phys.org
Before beginning, we note that $m \not=2$, or else the equation is not quadratic but linear. So, we assume $m \not=2$.
The quadratic formula yields
$$x= \frac{m+3 \pm \sqrt{(m+3)^{2}-4(m-2)(-2m-1)}}{2(m-2)}
= \frac{m+3 \pm \sqrt{m^{2}+6m+9-4(-2m^{2}+3m+2)}}{2(m-2)}$$
$$= \frac{m+3 \pm \sqrt{9m^{2}-6m+1}}{2(m-2)}
= \frac{m+3 \pm \sqrt{(3m-1)^{2}}}{2(m-2)}=
\frac{m+3 \pm |3m-1|}{2(m-2)}.$$
These two solutions will not change, actually, depending on whether $m<1/3$ or $m \ge 1/3$, since we're multiplying the absolute value by $\pm$. Hence, we have the solutions
$$x= \left \{-1,\;\frac{2m+1}{m-2} \right \}.$$
By some rearrangements :
\(\displaystyle m(x^2-x-2)-(2x^2+3x+1)=0\)
\(\displaystyle m(x-2)(x+1)-(2x+1)(x+1)=0\)
\(\displaystyle (x+1) \left(m(x-2)-(2x+1)\right)=0\)
Hence :
\(\displaystyle x=-1\) or
\(\displaystyle x=\frac{2m+1}{m-2}\)
FAQ: How Do You Solve This Specific Quadratic Equation?
What is a quadratic equation?
A quadratic equation is an equation of the form ax^2 + bx + c = 0, where a, b, and c are constants and x is the variable. It is called a quadratic equation because the highest power of x is 2.
How do you solve a quadratic equation?
To solve a quadratic equation, you can use the quadratic formula, which is x = (-b ± √(b^2 - 4ac)) / 2a. You can also factor the equation or complete the square to find the solutions.
What are the different types of solutions for a quadratic equation?
There are three types of solutions for a quadratic equation: two real solutions, one real solution, or two complex solutions. The number of solutions depends on the value of the discriminant, which is b^2 - 4ac.
What is the discriminant and how is it used to solve a quadratic equation?
The discriminant is the value b^2 - 4ac in a quadratic equation. It is used to determine the type of solutions the equation will have. If the discriminant is positive, the equation will have two real solutions. If it is zero, the equation will have one real solution. If it is negative, the equation will have two complex solutions.
Why are quadratic equations important in science?
Quadratic equations are important in science because they are used to model real-world phenomena, such as motion, growth, and decay. They are also used in various scientific fields, such as physics, chemistry, and engineering, to make predictions and solve problems.
