steem84
- 13
I am a little bit confused about solving the following equation:
(x-1)2(a+x)=1
How to do this??
(x-1)2(a+x)=1
How to do this??
steem84 said:well, actually this is the original equation (see figure1)
The solution is in figure 2..
So let me reformulate my question: Can this be proven analytically?
The expression (x-1)^2 * (a+x) can be simplified by using the distributive property. First, multiply (x-1)^2 to get x^2 - 2x + 1. Then, distribute this to (a+x) to get a(x^2) + (ax) - 2x^2 + x + 1. Finally, combine like terms to get a(x^2) - x^2 + (ax + x) + 1, which can be further simplified to (a-1)x^2 + (a+1)x + 1.
To solve for x, we need to isolate it on one side of the equation. First, distribute (x-1)^2 to get (a-1)x^2 + (a+1)x + 1 = 1. Then, subtract 1 from both sides to get (a-1)x^2 + (a+1)x = 0. We can then factor out x to get x((a-1)x + (a+1)) = 0. From here, we can use the zero product property and set each factor equal to 0 to solve for x. This will give us two possible solutions for x.
Yes, this equation can have complex solutions. When solving for x, we may end up with a quadratic equation that has complex roots. This means that the solutions for x will involve complex numbers, such as imaginary numbers.
Yes, you can check your solution by plugging it back into the original equation and solving for both sides. If the solution satisfies the equation, then it is correct. However, if it does not, then you may have made a mistake in your calculations.
Yes, this equation can be solved using the quadratic formula. After simplifying the expression and setting it equal to 0, we can compare it to the general quadratic equation, ax^2 + bx + c = 0. From there, we can use the quadratic formula to solve for x. However, it may be easier to factor the expression if possible before using the quadratic formula.
