How do you think about Subtraction?
  • Thread starter PhysicsHelp12
In summary, the conversation discusses different ways of thinking about algebra, specifically in terms of addition and subtraction. The concept of additive inverse is brought up, and how it relates to both addition and subtraction. The importance of understanding associativity and commutativity is also discussed. The conversation ends with the idea that having intuition and experience in algebra is just as valuable as being able to provide a proof.
PhysicsHelp12
58
The people on yahoo answers confused me ...and said I was doing it wrong
When you do algebra...you're supposed to think about it in terms of an additive inverse
(as multiplying by (-1) and adding it ) so you get communitivity and associativity, right?
Is that how you think of it -in terms of addition when doing algebra?
Mathematics news on Phys.org
How exactly do you mean think? Do you want the definition usually given, or the intuitive concept of subtraction. Normally we take it as an axiom that every x has an additive inverse y such that x+y=0, and we then think of subtraction as the addition of the additive inverse. Or in more ordinary terms we define -x to mean the additive inverse of x, and define x-y to be equal to x+(-y). Note that you would have to prove the uniqueness of the additive inverse for subtraction to be well-defined, but that's fairly trivial.
Of course all correct definitions are equal, so you can define it however you want. If you have defined -1 (the additive inverse of the identity), and multiplication between arbitrary elements then you can define x-y to mean x+(y*-1) and it would be just as valid as the first definition I gave (in fact they can be proven equivalent for most definitions of multiplication).
The problem with you approach is that for some groups we haven't defined a multiplication operator, we have defined several multiplication operators, or it doesn't behave like a normal multiplication operator. However for fields and rings the two definitions are equivalent.
I just realized that you may be only thinking of elementary algebra. If you are only working within the real or complex numbers then the definitions are equivalent as well, so yours isn't inferior in any sense.
Both subraction and division are not very good operations- in particular they are not 'associative'. It is much better to think of them just as adding the "additive inverse" and multiplying by the "multiplicative inverse".
Hi PhysicsHelp12! :smile:
Subtracting something is adding the inverse of it.
(and inverse can be defined without using multiplication, of course)
But …
… ...said I was doing it wrong
… how were you doing it? :smile:
My problem is ...I'm in university and I've been doing algebra for years now ...
so usually the right answer pops into my head without much conscious thought
but I am kind of getting worried/obsessive about 'What if I forget someday if it always
just comes to me without actually thinking much about it"
so I've been trying to think of what rules exactly I am applying --
but then there's trivial ones like associativity or commutivity that I don't think about
so Is it ok to just --Let the answer cometo you from experience --without actually
THinking about the way the rule was initially presented in its simplest form if you know its right
Eg. 1/x=x^(-1) was the basic rule
but then you apply it to a rational expression ...then technically youre using associativity ...i mean ...whats the process
ab/(cd)=ab/c*d^(-1)
...but youre using associativity arent you?
a*b/(c*d)=a*b/c*(1/d) =a*b/c*(d^(-1))=a*b/c*d^(-1)
Do you see my frustration --trying to do it completely axiomatically ..with associativity
and then it takes 10 minutes --
even though I know by experience
idk ...
Analysis and Abstract algebra have made me crazy I think...
Apply the rules to check your answer or provide a proof of your intuition to other mathematicians. Intuition and foresight is just as valuable as being able to provide a proper proof. Sometimes your intuition will be wrong, usually because you're dealing with a mathematical object you have not had past experience with, or dealt with at the same depth of analysis. Attempting to prove the statement your intuition makes will then show you your error and beef up your experience.
PhysicsHelp12 said:
… so I've been trying to think of what rules exactly I am applying --
Eg. …
ab/(cd)=ab/c*d^(-1)
It's a ball-park thing …
just remember which ball-park you're in! :biggrin:
Once you're happy that associativity and commutativity apply, then yes you can forget about them.
Don't worry! :wink:
Actually I think of subtraction both as the subtraction operation AND as the additive inverse; switching between the two ways of thinking is not difficult (is this just ME and a few other people, or is this ME and most other people?). I use the form which is most convenient at the time.
Ok that makes a lot of sense Thx Tiny-Tim :)
FAQ: How do you think about Subtraction?
How does subtraction differ from addition?
Subtraction is the mathematical operation of finding the difference between two numbers. It is the inverse of addition, meaning that it "undoes" what addition does. While addition combines two or more numbers, subtraction separates them.
What are some real-life examples of subtraction?
Subtraction is commonly used in everyday life, such as calculating change when making a purchase, determining how much time is left before an event, or finding the difference in temperature between two days.
Can subtraction be done with negative numbers?
Yes, subtraction can be done with negative numbers. When subtracting a positive number from a negative number, it is equivalent to adding a negative number to another negative number. For example, -5 - 3 = -8.
How do you check your answer when subtracting?
To check your answer when subtracting, you can use the inverse operation of addition. Add your answer to the number you subtracted from, and the result should be the number you started with. For example, 10 - 4 = 6, and 6 + 4 = 10.
Are there different methods for subtracting?
Yes, there are different methods for subtracting, such as the traditional algorithm (borrowing and carrying over numbers), using a number line, using manipulatives, and mental math strategies. The method used may depend on the numbers being subtracted and personal preference.
