How do you Treat Infinitesimals?
In summary, all throughout calculus texts, the authors have always put conditions on the manipulation of differentials. They say that for the chain rule, the cancellation of the differentials is simply a way to remember the formula. When doing separation of variable for ODEs, texts always say something like: "Oh, so we group the ##dy##'s and ##dx##'s on both sides, even though that is kind of a handwavy way of handling the differentials and it's not how they actually work" or something like that. There is always some little side note that the manipulation isn't rigorous. However, it's helpful to distinguish between exploration and proof. When one is exploring possible avenues for a proof,
TheDemx27
All throughout calculus texts, the authors have always put conditions on the manipulation of differentials. They say that for the chain rule, the cancellation of the differentials is simply a way to remember the formula. When doing separation of variable for ODEs, texts always say something like: "Oh, so we group the ##dy##'s and ##dx##'s on both sides, even though that is kind of a handwavy way of handling the differentials and it's not how they actually work" or something like that. There is always some little side note that the manipulation isn't rigorous. In all my experiences, treating the differentials as variables and manipulating them as such works out fine.
How are you actually supposed to treat infinitesimals then?
It is a valuable exercise to work to understand the rigorous justification for the cases where dx terms are treated like ordinary numbers. Usually it's not too hard to understand. For instance the proof of the validity of the chain rule has nothing to do with cancelling out infinitesimals. All cancelling is done on finite quantities inside the limit parentheses. Separation of variables to get from ##\frac{dy}{dx}=\frac{f(x)}{g(y)}## to ##\int g(y)dy=\int f(x)dx## can be done by multiplying both sides by ##g(y)##, integrating wrt x and then using substitution and the chain rule.
When you've done that for the main cases, you can apply the rule of thumb that there's a good chance it's illegal if you can't think of a rigorous justification.
However, it's helpful to distinguish between exploration and proof. When one is exploring possible avenues for a proof, it can be efficient to just assume without proof one can manipulate the differentials, in order to go on and see what happens next. If it turns out to be a dead end anyway, one will have saved the time it would have taken to justify the manipulation. If it turns out to not be a dead end, one can then go back and try to justify the manipulation.
Actually, most Calculus texts, all those except the relatively new "non-standard Analysis" texts, don't mention "infinitesmals" at all, they deal with limits instead
Likes hunt_mat
[tex]\frac{dy}{dx}=\frac{f(x)}{g(y)}[/tex]
[tex]\int g(y)\frac{dy}{dx} dx =\int f(x)dx[/tex]
I don't know what bit of meaningful substitution you could do here.
andrewkirk said:
##u=y, du=\frac{dy}{dx}dx##
##\int g(y)\frac{dy}{dx} dx=\int f(x)dx##
##\int g(u)du =\int f(x)dx##
and ##u=y## so
Is that what you meant?
You confused me by using the word "infinitesmals" in the title of the thread when the thread is really about "differentials"!
and ##u=y## so
Yes, that's it.
Sorry about that. I guess I don't know the difference between the two. Wikipedia seems to think they are the same thing. I'm guessing differentials are a subset of infinitesimals?
No, "infinitesimals" don't exist at all in the usual real number system. In "non-standard analysis", that I referred to above, "infinitesimals" are developed by constructing an entirely new number system that includes numbers, in addition to the usual real numbers, called "infinitesimals": https://en.wikipedia.org/wiki/Non-standard_analysis
Differentials, on the other hand, are an operation on functions- given any function, f, such that [itex]\frac{df}{dx}= g[/itex], the "differential" is defined as [itex]df= g(x)dx[/itex] and "dx" is essentially left undefined. In ordinary Calculus, "df= g(x)dx" can be approximated by using a small value for dx. In non-standard analysis "differentials" can be identified with "infinitesimals".
Likes TheDemx27
Related to How do you Treat Infinitesimals?
1. What are infinitesimals and why are they important in science?
Infinitesimals are mathematical quantities that are infinitely small and non-zero. They are important in science because they allow us to accurately describe and understand the behavior of complex systems, such as in calculus and physics.
2. How do you treat infinitesimals in mathematical equations?
Infinitesimals are treated as limits in mathematical equations. This means that they are approached closer and closer to zero, but never actually reaching it. This allows us to work with infinitesimals without encountering any mathematical inconsistencies.
3. Are infinitesimals used in everyday applications?
Yes, infinitesimals are used in everyday applications, although we may not always be aware of it. For example, they are used in computer graphics to create smooth curves and surfaces, in finance to model continuous changes in stock prices, and in engineering to design efficient structures.
4. How do you handle infinitesimals in experimental data?
In experimental data, infinitesimals are often treated as uncertainties or errors. They can also be accounted for through statistical analysis and mathematical modeling. It is important to acknowledge and address infinitesimal values in order to accurately interpret experimental results.
5. Are there any limitations or challenges in working with infinitesimals?
Yes, there are some limitations and challenges in working with infinitesimals. One of the main challenges is that they can lead to mathematical paradoxes and inconsistencies if not handled properly. Additionally, there are some mathematical operations, such as division by zero, that cannot be performed with infinitesimals. However, these challenges can be overcome with the use of rigorous mathematical techniques and frameworks, such as non-standard analysis.
  • Calculus
  • Calculus
