How Does 5% Scattered Light Affect Equivalent Width?
The introduction of 5% scattered light affects the equivalent width by altering the continuum flux (F_c) and the line flux (F_ν). The equivalent width is calculated using the integral of the ratio of these fluxes, and the change in equivalent width depends on the spectral range chosen. For a range of 200 Angstroms, the equivalent width could change by 10 Angstroms, while a narrower line width of 140 Angstroms would result in a change of 0.7 Angstroms. Additionally, there are concerns about potential errors in the equations presented, such as unit consistency and the lack of instrument-specific information. Understanding how scattered light impacts the flux measurements is crucial for accurate calculations of equivalent width.
AlphaCrucis
How much does the equivalent width of a line change by the introduction of 5% scattered light?
Below
How much does the equivalent width of a line change by the introduction of 5% scattered light? We know the equivalent width is defined as
We know the equivalent width is defined as $$W = \int_{-\infty}^{\infty} \bigg(\frac{1-F_{\nu}}{F_c}\bigg) \, d\nu$$ where ##F_{\nu}## represents the flux in the line and ##F_c## represents the flux in the continuum.
The measured equivalent width is $$W_m = \int_{-\lambda_o}^{\lambda_o} \frac{I(\lambda)*(F_c - F_\nu)}{D_c} \, d\nu$$ in which ##\lambda_o## is the spectral range over which the profile can be traced, ##I(\lambda)## is the instrumental profile, and ##D_c## is the apparent continuum.
If we choose ##\lambda## to be 0 at the center of the line, and the range spans 200 Angstroms, then does the equivalent width of the line change by ##200 A \cdot 0.05## = 10 A? So is the equivalent width of a line changed depends on our range? I.e. width of a line of 140 Angstroms with 5% scattered light would alter it by 0.7 A. Am I correct?
Couple of things.
There is an error here, could just be a latex typo. What are the units of the integrand, as written above? Are they consistent?
There is no information given about the instrument, so you are only solving for the equivalent width not the measured equivalent width.
To get you started: How does the addition of 5% scattered light change ##F_c## and ##F_\nu##?
Likes AlphaCrucis
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
