MHB How Does a 1% Increase in Dimensions Affect the Volume of a Slab?
  • Thread starter Thread starter abhay1
    Volume
A 1% increase in each dimension (width, length, height) of a slab, represented by the volume formula V = xyz, results in a new volume calculated as V = (1.01x)(1.01y)(1.01z). This simplifies to V = (1.01)^3 * V_0, indicating that the volume increases by a factor of approximately 1.030301. Therefore, the overall increase in volume is about 3.03%. The discussion highlights the application of partial differential equations to understand volume changes due to dimensional increases. The calculations confirm that even small percentage increases in dimensions can lead to significant changes in volume.
abhay1
Fig.(1) shows a slab whose volume V is given by
V = xyz.
If the width, the length and the height of the slab, each increases by 1%, what is the
increase in its volume?
Mathematics news on Phys.org
Re: partial differential equations
V = xyz.
What figure?
I'm going guess that one corner of your slab is at the origin and everything is all nice and perpendicular.
So: [math]V_0 = xyz[/math] (Your original volume.)
Now, if we add 1% to x then we have x + 0.01x = 1.01x. Similar for the other dimensions. So [math]V = (1.01x)(1.01y)(1.01z) = (1.01)^3 xyz = (1.01)^3 V_0[/math]
What is the increase in volume here?
-Dan
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
