How does a 4x4 Keypad work with PIC 16f877A?
  • Thread starter kloong
  • Tags
    Work
In summary, the PIC scans the rows and columns of the keypad by setting one column to 0V and reading the inputs to determine which buttons are pressed in that row. This process is repeated for each column to scan the entire keypad. The internal pull-ups are used to maintain a 5V signal when no buttons are pressed. The attached drawing illustrates this process in more detail.
Normally, your inputs B0 through B3 are configured so that the internal pull-ups are on (that way, when you read these inputs, you see 5V, or a logic 1). You normally have the outputs B4-B7 set to 5V.
Now, when you want to scan a column, say, the first one, you set one of the outputs (in this case, B4) to 0V, logic 0.
You then read the inputs. If any of yhebuttons are pressed in this column, you'll read 0 on those pins. If buttons SW1 or SW9 were pressed, they would connect 0V across the button and you would read 0 on pins B0 and B2, and 1 on pins B1 and B3.
By successively setting each individual column to 0, and then reading the inputs to see which buttons are pressed in that row, you can figure out which buttons are pressed in the entire keypad.
Related to How does a 4x4 Keypad work with PIC 16f877A?
1. How does a 4x4 keypad communicate with a PIC 16f877A microcontroller?
The 4x4 keypad uses a matrix arrangement of rows and columns to send signals to the PIC 16f877A. Each key on the keypad corresponds to a unique combination of row and column, and when a key is pressed, the corresponding row and column pins are connected, allowing the microcontroller to detect which key was pressed.
2. What is the process of connecting a 4x4 keypad to a PIC 16f877A?
To connect a 4x4 keypad to a PIC 16f877A, the rows and columns of the keypad must be connected to the input/output (I/O) pins of the microcontroller. The keypad also needs a power supply and ground connection. Additionally, pull-up resistors may be needed to ensure accurate detection of key presses.
3. How does the PIC 16f877A detect which key was pressed on the 4x4 keypad?
The PIC 16f877A uses a scanning technique to detect key presses on the 4x4 keypad. It sequentially scans each row of the keypad by sending a low voltage signal to each row and reading the corresponding column pins. If a key is pressed, the row and column pins will be connected, and the microcontroller will detect this change in voltage and determine which key was pressed.
4. Can the 4x4 keypad be used for both input and output with the PIC 16f877A?
Yes, the 4x4 keypad can be used for both input and output with the PIC 16f877A. The microcontroller can send data to the keypad to be displayed, such as numbers or letters, and it can also read input from the keypad when keys are pressed.
5. Are there any limitations to using a 4x4 keypad with a PIC 16f877A?
One limitation of using a 4x4 keypad with a PIC 16f877A is the number of available pins on the microcontroller. The keypad requires eight pins for the rows and columns, which may limit the number of other devices or components that can be connected to the microcontroller. Additionally, the keypad may not be suitable for complex input, such as long strings of characters, due to the limited number of keys available.
  • Mechanical Engineering
  • Electromagnetism
  • General Engineering
  • Classical Physics
  • Classical Physics
