How Does a Capacitor Discharge Over Time?
In summary, the conversation revolved around the theory of a capacitor discharging, its relevance to a lab experiment, and how to properly explain it in an introduction. The theory of a capacitor discharging involves an inverse exponential rate of charging, where the current becomes effectively zero and the voltage across the capacitor becomes effectively the applied voltage after a time proportional to the product of resistance and capacitance. The electrons flow around the circuit externally while the capacitor is charging or discharging, and the rate of discharge decays exponentially with time. The conversation also highlighted the importance of properly explaining the theory and equations in the introduction.
Tobus
Hi,
I am studying an engineering program in university. I have a piece of lab coursework to do and I am struggling to find information on it.
The lab report was based on 'The discharge of a capacitor with time using an oscilloscope'
It sounds silly but what is the theory of a capacitor discharging? I also need to find the principle of why is discharges relevant to the experiment at hand.
I know I'm asking a lot but I think I'm in the right place to ask :)
A huge thanks to anyone that can help me :)
Hi Tobus! :smile:
From capacitor in the PF Library
Inverse exponential rate of charging:
A capacitor does not charge or discharge instantly.
When a steady voltage [itex]V_1[/itex] is first applied, through a circuit of resistance [itex]R[/itex], to a capacitor across which there is already a voltage [itex]V_0[/itex], both the charging current [itex]I[/itex] in the circuit and the voltage difference [itex]V_1\,-\,V[/itex] change exponentially, with a parameter [itex]-1/CR[/itex]:
[tex]I(t) = \frac{V_1\,-\,V_0}{R}\,e^{-\frac{1}{CR}\,t}[/tex]
[tex]V_1\ -\ V(t) = (V_1\,-\,V_0)\,e^{-\frac{1}{CR}\,t}[/tex]
So the current becomes effectively zero, and the voltage across the capacitor becomes effectively [itex]V_1[/itex], after a time proportional to [itex]CR[/itex].
Hey thanks :)
Thank you for the help,
For my introduction I have written this,
"We are doing this experiment to understand if the capacitor discharges at a particular rate to show that the theory of a capacitor discharges at an exponential rate when a direct current is removed. Capacitors are used in many circuits and electronic storage devices. As the capacitor is charged from the direct current supplied there is a force of attraction between the two plates as one becomes positively charged and the other becomes negatively charged. Once the charge/voltage? has been removed the capacitor starts to discharge and the flow of electrons moves across the plates. The rate of discharge decays exponentially to time."
What do you think, do I get my point across properly? More importantly is the physics correct! lol
Hi Tobus!
hmm …
i] the electrons do not move across the plates … they go the long way round!
ii] you haven't actually explained anything … why do the electrons go the long way round (especially when, as you point out, there's an attractive force the short way round) … and why is it exponential, or at least, what is the governing equation? :smile:
What do you mean by long way around :S. Sorry I'm not so sure lol.
I know its exponential decay as the current decreases at the same ratio in successive equal intervals of time.
How about that? Do you think I should put it in somewhere.
For my introduction I simply need to explain the theory of what a capacitor does. :)
Again from PF Library:
Displacement current:
No current ever flows through a functioning capacitor.
But while a capacitor is charging or discharging (that is, neither at zero nor maximum charge), current is flowing round the circuit joining the plates externally …​
but why? (how does it know? :biggrin:)
FAQ: How Does a Capacitor Discharge Over Time?
1. What is a capacitor discharge report?
A capacitor discharge report is a detailed document that outlines the results of testing a capacitor and its discharge characteristics. It includes information such as the capacitor's voltage, current, and time relationships, as well as any abnormalities or issues that were observed during the testing process.
2. Why is urgent help needed for a capacitor discharge report?
Urgent help is needed for a capacitor discharge report because it indicates that there may be a problem with the capacitor that requires immediate attention. If the capacitor is not functioning properly, it could lead to equipment failure or safety hazards.
3. What are some common issues found in a capacitor discharge report?
Some common issues found in a capacitor discharge report include high leakage current, abnormal voltage or current readings, and shorted or open capacitors. These issues can lead to a decrease in the effectiveness of the capacitor or cause it to fail altogether.
4. How is a capacitor discharge report used?
A capacitor discharge report is used to assess the health and functionality of a capacitor. It is often used in quality control and maintenance processes to ensure that capacitors are functioning properly and to identify any potential issues that may need to be addressed.
5. Can a capacitor discharge report be used to predict future failures?
Yes, a capacitor discharge report can be used to predict future failures by identifying any abnormalities or issues with the capacitor. By addressing these issues, the lifespan of the capacitor can be extended and potential failures can be prevented.
