How does a clay pot cool water?
In summary, Russ says that the air next to the uglazed clay pot will be cooler than the surrounding air.
M.Kalai vanan
32
From things I've read it states that water oozes through pores of clay pot to outer surface and absorbs the heat form outer air.The heat absorbed is latent heat for water and specific heat for air outside which lowers the air temperature and as evaporation on outer surface takes place water inside gets cooled.
My doubts are
1) If the water gains latent heat and evaporates then there should be no temperature change within the water inside.Then how come water inside pot cools down
From what you are describing, water in an uglazed clay pot used to cool air, by absorbing heat from the air, the water in the pot gets warmer, not cooler.
The heat to evaporate the water exiting the pores is supplied mainly by the clay pot (although part of it also comes from the surrounding air). The evaporation causes the outer surface of the clay pot to cool, just like evaporation of sweat from your body cools your skin on a hot day. The cooler surface temperature of the clay pot causes heat to be conducted from the water inside the pot to the cool outer surface, thus cooling the liquid inside.
Chet
@ Chestermiller
If a part of latent of vaporization of water is taken from pot then the resulting air would have a higher enthalpy value than the initial condition since some part of heat is externally added from pot.Then how come the air has an constant enthalpy value as stated in http://en.wikipedia.org/wiki/Evaporative_cooler
M.Kalai vanan said:
@ Chestermiller
The is no "extra heat" available for heating anything. The evaporating water acts as a heat sink, not as a heat source. So, if anything, the air next to the pot will be cooler than the surrounding air.
Chet
I think that statement adds confusion. The water on the surface of the pot will lose heat because the water molecules that are blown away from the surface are those with higher Kinetic Energy than average. They take net energy from the cooler +water+ beer and lower the temperature.
The limit to the amount of cooling is set when the temperature gets low enough for fewer molecules to be lost. A fast current of air will, of course, increase the cooling effect as the faster molecules can never return to the pot surface.
M.Kalai vanan said:
@ Chestermiller
If a part of latent of vaporization of water is taken from pot then the resulting air would have a higher enthalpy value than the initial condition since some part of heat is externally added from pot. Then how come the air has an constant enthalpy value as stated in http://en.wikipedia.org/wiki/Evaporative_cooler
That's an idealization that assumes the system is in a perfect steady-state. In a perfect steady-state, the enthalpy of the air and water are equal and remain equal because while the evaporating water is adding enthalpy to the air, the air is also heating the water, at exactly the same rate, so the enthalpy remains constant in both.
Are we not losing sight of the fact that this sort of cooling system actually works?? Some of the comments in the thread seem to be indicating that it doesn't, which is nonsense.
The reason is that it isn't an equilibrium situation because the external air is constantly being changed. It's pretty obvious that, if you kept the unglazed pot in a plastic bag, the cooling wouldn't work. What is needed is an explanation of why it works when it works.
The enthalpy that the vapor adds to the air is at the same temperature as the evaporating liquid (i.e., cold). At steady state, the water vapor is diffusing away from the surface of the pot and into the surroundings (which have infinite capacity to accept it). The transport of water vapor away from the pot is also aided by convection in the air. So the rate of evaporation is constant, and the rate of cooling is constant.
Russ, in your above post, I think you meant to use the word "constant" in all locations in the second sentence where you used the word "equal."
Chet
Related to How does a clay pot cool water?
1. How does clay pot cool water?
Clay is a porous material, meaning it has tiny holes or spaces that allow air and moisture to pass through. When water is poured into a clay pot, the moisture from the water seeps through the pores in the clay and evaporates on the surface, causing the water to cool down.
2. Can any type of clay pot cool water?
Yes, any type of clay pot can cool water as long as it is unglazed. Glazed clay pots have a waterproof coating that prevents water from seeping through the pores and therefore they will not be effective in cooling water.
3. How long does it take for a clay pot to cool water?
The cooling time of water in a clay pot depends on various factors such as the size of the pot, the temperature of the water, and the surrounding environment. On average, it can take anywhere from 30 minutes to an hour for the water to cool down significantly.
4. Can clay pots cool water in hot weather?
Yes, clay pots are especially effective in cooling water during hot weather. This is because the temperature difference between the hot environment and the cooler water inside the pot creates a stronger evaporation process, resulting in faster cooling.
5. How many times can you use a clay pot to cool water?
Clay pots can be used multiple times to cool water as long as they are properly maintained. It is important to clean the pot after each use to prevent bacteria and mold growth. Also, over time, the clay pot may develop cracks or become less porous, which can affect its cooling abilities.
  • Mechanics
32K
  • Mechanics
