How does a digital ammeter work?
In summary, my textbook does a poor job of explaining how a digital ammeter works. The description of how digital ammeters work in my textbook is incomplete and does not accurately reflect how digital ammeters work. A digital ammeter measures current by having a coil that is deflected by magnetic forces from electric current.
fourthindiana
162
25
I am a student at a trade school, majoring in HVAC. My electricity for HVAC textbook has a chapter on electric meters. However, my textbook does a poor job of explaining how a digital ammeter works.
My textbook has the following description of how digital ammeters work: "To make meters useful in line-current measuring systems, a shunt is installed within the meter. The shunt is a low resistance current path that allows a proportional amount of current to flow through the meter movement...Suppose that a 1-ampere full-scale meter is designed using a meter movement that requires .001 amperes (1 milliampere, mA) full scale deflection. The meter movement resistance is 100 ohms. According to Ohm's Law, there will be a 0.001 A X 100 ohm = 0.1 V across the meter movement at full-scale deflection. The scale of the meter would be changed to indicate 1 ampere instead of 1 mA, but it would still take only 1 mA through the meter movement to cause full-scale deflection."
I understand that most of the current goes through the shunt, and a minority of the current goes through the "meter movement". However, I don't know exactly what "meter movement" means in this context. I know that analog ammeters have a coil that is caused to move by magnetic forces when a current flows through the coil. The coil is attached to the dial of the analog ammeter in such a way that when a magnetic field moves the coil, the dial is also moved, calibrated in such a way as to indicate the current going through the analog ammeter. Perhaps a digital ammeter also has a coil that measures current by being deflected by magnetic fields from current. However, my books never mentions that a digital ammeter also has a coil that is deflected by magnetic fields from electric current.
Does a digital ammeter measure current by having a coil that is deflected by magnetic forces from currents in a way similar to how analog ammeters measure current by having a coil that is deflected by magnetic forces from currents? If not, how do digital ammeters measure current?
I think the digital multi meter uses a microchip to detect a voltage/amperage which is then converted into an output to a numerical display based on the magnitude of the input. No mechanical parts.
Likes fourthindiana
There is no coil in a DMM -- coils were used a couple centuries ago for current measurement with analog meters (I've read about them, but I'm way too young to have ever seen one). :wink:
The DMM measures current by measuring the voltage across a known, internal shunt resistance. For the more sensitive measurements (like 1mA full scale, it may use a 100 Ohm shunt. For higher current measurements, a lower resistance shunt like 0.1 Ohm would be used. You don't want the shunt resistance to interfere with the measurement, but it can if the DMM user doesn't understand how the current meter feature is implemented.
Most DMMs also have a fuse in series with the current measurement input, and the fuse will blow if you try to use the DMM to measure too high of a current. Please do not ask me how I know this...
Likes sparkie, davenn and fourthindiana
Hah! Then you've missed the fun of "pinning the meter", driving it so hard that the needle hits the little pin at the top of the scale and wraps itself around it.
Note to self: don't put several amps through a milliammeter.
It sounds like the author cut and pasted a description of an analog meter from an old edition of the textbook and then just added a couple of words about "digital" up front. As @berkeman said, a digital ammeter is a digital volt meter calibrated to determine the current from the voltage across a known resistor.
You turned it up to eleven! :wideeyed:
:biggrin: There's got to be a good story hidden there. :biggrin:
And Fluke DMM fuses are not available at the local Radio Shack either. I also know this.
And if you put AC into a DC milliammeter, the needle vibrates so fast that it disappears. Amazingly enough, that stunt did not let the smoke out of the meter.
Likes berkeman
Mostly this:
I still haven't been able to find a fuse that fits to replace the mA scale fuse. Sigh.
First of all, I am asking about a digital ammeter, not a digital multimeter. I know that a multimeter can measure amperage. However, a multimeter might measure amperage differently than how an ammeter measures amperage.
If an ammeter measures amperage using a microchip to detect an amperage which is then converted into an output to a numerical display based on the magnitude of the input, that still does not really explain to me exactly how the ammeter works. I mean, how does the microchip measure the amount of current running through the microchip? It's not like the microchip can count each individual electron flowing through the microchip.
What is a "digital ammeter" and how is it different from a DMM used with its current input? Can you post some links or datasheet info?
Remember that I asked about digital ammeters, not digital multimeters.
Your answer assumes that I know how digital multimeters measure voltage. The problem is that I don't know how digital multimeters measure voltage. How does a digital multimeter measure the voltage across a known, internal shunt resistance?
I'm a student at a trade school, not an electrical engineer.
Do you have access to Google?
A digital ammeter is an electronic meter with a digital display that only measures amperage. I don't have any datasheet info.
My textbook describes digital ammeters, not digital multimeters. After thinking more about this, I suppose a digital ammeter probably measures current the same way that a digital multimeter would measure current.
This is not a question like "Who was the 16th President of the United States?" or "Is a frog a reptile or an amphibian?" This is not the type of question in which I can get an answer from google.
It's going to take human help. If information like this could be ascertained from google, this website would not exist.
Yes, exactly. I suppose somebody could put together a strange combo retro intrument @davenn ? that would digitize the analog meter movement from the old coil-based ammeters, but other than the novelty, I don't know why they would do that.
All modern current measurements that I know about with simple meters use the precision shunt resistance and the voltage measurement capability of the DMM core circuitry.
BTW, you will probably work some with clamp-on current meters at some point in your HVAC training and work. If the current is AC, you can just use a simple clamp-on AC sensing coil attachment for your DMM. For measuring DC currents with a clamp-on meter attachment, the attachment will need to be Hall-Effect based. You can find some interesting reading by using Google with Hall Effect Meter Clamp as the search terms. :smile:
How does the DMM core circuitry measure voltage?
I have used clamp on current meters in my HVAC training. But I know how the clamp on current meters measure current.
BTW, I googled "How does a multimeter measure AC voltage" and I got a lot of links explaining how to measure ac voltage in a circuit using a multimeter, but I could not find anything explaining how the multimeter itself measure the voltage.
I can help with some Google search terms if you like. Learning to use Google for technical searches is a valuable skill that will serve you well. It certainly helps me every day in my full-time EE R&D Lab work. :smile:
I like to use Google Images to help me focus my searches. Maybe try that? If you can link to a schematic, we can help to explain it.
Likes davenn
irrelevant …. the processes are the same
@berkeman has already given you the answers but you seem reluctant to accept them
It doesn't matter if it is a stand alone digital voltmeter or ammeter or both built into a multimeter package … it uses the same principles
that Berkeman stated
For voltage …. the voltage being measured gets digitised in a ADC (analog to digital converter) which is then used to drive the display driver and then displayed.
commonly, these days, the ADC and display driver are in the one package … The ICL7106 was a common chip for doing this even up to 30 yrs ago.
The current measurement just has an extra stage on the front end, as Berkeman also described in several earlier posts eg ……
I googles circuit of a digital multimeter and got a bunch of circuit diagrams …. I'm sure you could do the sameDave
Likes phinds and berkeman
Most digital meters (voltmeters, ammeters, multimeters, even temperature meters - though not frequency meters and related ones) work by measuring voltage.
The ammeter uses a shunt through which the current flows to produce a voltage to be measured by the electronics of the meter.
For an electronic digital meter, the input resistance is (usually) so high that the input current can be neglected. Just take the full input voltage of the meter circuit, say 1 V, the full scale current you want to measure, say 1 mA, which means you need a resistance of 1 kΩ for your shunt. Connect the digital meter across this.
When 1 mA flows through the 1 kΩ shunt, you get 1 V for a reading of 1.000. For smaller currents you get smaller voltages and the reading will tell you the current in mA, so 0.3 mA through 1 kΩ gives 0.3 V for a reading of 0.300, etc.
The 10 MΩ or more input resistance is 10,000 x greater than the shunt, so won't matter unless you're going for more than 4 digit accuracy. Then you need to know your actual input resistance to calculate the shunt. Or more likely, you still use a similar shunt, but can adjust the sensitivity of the meter a little, so that you calibrate it to read exactly what it should.
A multimeter just uses a digital voltmeter and measures various voltage and current ranges by using combinations of resistors, large ones in series (for voltage) or small ones in parallel (shunts for currents) to get the range required. Most have other functions like; resistance, requiring a current source; frequency using the counter and crystal clock; capacitance and inductance based on the frequency counter; temperature based on the voltmeter or resistance meter.
The basic voltmeter function can be implemented in several ways, but I think commonly it is done by charging a capacitor connected to the input voltage (or a fraction of it) for a full scale count, then discharging connected to a reference voltage source in the meter and counting how long it takes. If the input voltage equals the reference, discharge takes as long as charge, so you get the full scale count. If the input is only half the reference, it gets discharged in half the time from the full reference voltage, so you get half the full scale count. (It's a lot easier to understand with graphs. Look up "dual slope integration". OIC, Dave has quoted the ICL7106 which has this info)
Likes berkeman
I should have really added this in the previous post, just to make it really clear
ALL meters …. current, voltage, resistance, analog or digital, measure a voltage which is then directly displayed or digitised then displayed
:wink:
yes, this is what he has been told for several posts
Merlin: "The ammeter uses a shunt through which the current flows to produce a voltage to be measured by the electronics of the meter."
davenn said:
:wink:yes, this is what he has been told for several posts
Yes, I originally asked "how does an ammeter/digital multimeter measure current?" Then I was told by many people that a DMM uses a shunt through which current flows to produce a voltage, and the DMM measures the voltage. Then the DMM uses Ohm's Law to calculate the current from the known voltage and known resistance. I understand all that. I don't deny that.
How does the electronics of the digital multi-meter measure the VOLTAGE of the current that goes through the shunt? Nobody has explained that yet.
YOu haven't made it really clear, davenn. You're just assuming that I know how a DMM measures the voltage, and I don't.
Is this how a DMM measures voltage? Are you saying that a DMM measures the voltage from the current run through a shunt by charging a capacitor and then somehow discharging the same capacitor and counting how long it takes for the capacitor to discharge?
Help vampire thread closed.
Likes anorlunda, phinds and davenn
BTW, several member were also trying to help the OP via PM to understand how ADCs work. There was some confusion about the fact that there are a number of different topology ADCs that are used in different situations and products. Below is my latest PM to this OP to try to clear up the confusion. Thank you to all members who are trying to help the OP out. :smile:
It's a simple issue. Yes, DMMs use ADCs to convert the voltages into digital numbers. There are a number of different ADC types, and possibly all are used in different versions of DMMs. You can read more about them at Wikipedia, using these search terms:
  • Successive Approximation ADC (very typically used)
  • Flash ADC (fastest, but much more circuitry)
  • Dual-Slope ADC (that's the charge time - discharge time version that folks are mentioning to you)
For cost reasons, I would expect most inexpensive DMMs to use the Successive Approximation ADC.
Hope that helps. I'll take another look at your thread to see if there is a reason to re-open it to clarify this.
Likes NTL2009, davenn and fourthindiana
Related to How does a digital ammeter work?
1. How does a digital ammeter measure current?
A digital ammeter works by measuring the voltage drop across a precision resistor, known as a shunt, in a circuit. The amount of current passing through the shunt is directly proportional to the voltage drop, which is then converted into a digital reading by the ammeter's internal circuitry.
2. What is the difference between a digital ammeter and an analog ammeter?
A digital ammeter displays current measurements as numerical values on a digital screen, while an analog ammeter uses a needle or pointer on a dial to indicate the current. Digital ammeters also tend to have a higher precision and accuracy compared to analog ammeters.
3. How does a digital ammeter handle different units of measurement?
Most digital ammeters allow the user to select the desired unit of measurement, such as amps, milliamps, or microamps. The ammeter's internal circuitry then converts the voltage drop into the selected unit of measurement and displays it on the screen.
4. Can a digital ammeter measure both AC and DC current?
Yes, many digital ammeters are designed to measure both AC and DC current. However, it is important to ensure that the ammeter is set to the correct mode before taking a measurement, as using the wrong mode can result in inaccurate readings or damage to the ammeter.
5. What are the benefits of using a digital ammeter?
Digital ammeters offer several advantages over analog ammeters, including higher precision and accuracy, the ability to measure both AC and DC current, and the option to select different units of measurement. They also often have additional features such as data logging and auto-ranging capabilities.
  • Electrical Engineering
