How does a fan cool your skin, exactly?
In summary: But if you were to reduce the static air pressure to almost a vacuum, and then move the air, you would notice a big temperature drop.In summary, the only reason air moving over your body caused by a fan or breeze feels cool is due to increased evaporation of moisture from your skin. The air does not blow away warmed air from your skin, but rather replaces it with relatively cooler air. Additionally, air movement can produce a small amount of heat due to increased kinetic energy and air pressure, but this is outweighed by the cooling effect of the moving air. In extreme conditions, such as high winds or low pressure, the temperature difference between moving and static air can be significant.
brainstorm
568
Is the only reason air moving over your body caused by a fan or breeze feels cool because of increased evaporation of moisture from your skin? Or does it blow air being warmed by your skin away from your body to be replaced with relatively cooler air?
Also, does air movement also produce some amount of heat, albeit very small? I wonder this because it seems like the air movement would increase the kinetic energy of air against your body and maybe also raise the air pressure as well. Is heat produced as well as mitigated by a fan?
Yes. Yes. Yes. Yes.
In that order.
OmCheeto said:
Yes. Yes. Yes. Yes.
In that order.
Gee, I was hoping I was thinking some of it wrong and I would learn something from posting it as a question.
brainstorm said:
... Or does it blow air being warmed by your skin away from your body to be replaced with relatively cooler air?...
Cannot be said any better without equations.
Moving air would produce heat if it were directed to air that was colder. Perhaps if you blew a strong enough fan on snow, a small part of it might melt. In usual settings though, hot still air contains more energy than the incoming fan air.
Well, you were wrong in that assumption. Jeez, what a dummy! :biggrin:
Even in the absence of evaporative cooling (sweat), the body still transfers heat to its surroundings by conduction and radiation. Replacing that surrounding air with a fresh batch of lower temperature will be felt as cooling. If the incoming air was hotter, you would feel that as well, but not in a pleasant way (unless it's winter, which it pretty much always is where I live; it's supposed to snow again tonight, and I'm not happy about it).
If the in-coming air was hotter, would evaporation-cooling still increase due to the air-movement and would this outweigh the effect of the incoming heat?
This makes me think of those guys stuck in the collapsed mine shaft. I believe I heard the temperature in the mine is in the upper 30s (celsius) and it doesn't cool down at night. At least they seem to have plenty of room to walk around.
I believe that it would depend upon both the temperature and the speed of the airstream. The blast wave from a nuke might be traveling at 2,000 km/h when it hits, but at 1,000° C it's still going to burn you. (Alright, that's an extreme example that overlooks the obvious, but it's just a "for instance".)
I remember some years ago atop the 6000 ft summit of Mount Washington in New Hampshire (USA) when the air temp was 35 below zero( degrees F) and the wind was blowing at hurricane strength. The Wind Chill factor (a measure of what it feels like, compared to a near calm wind at that air temperature, due to heat loss), was something like 80 degrees (F) below zero! Skin would freeze in a matter of seconds under those conditions.
Welcome to winter in Alberta.
Because of friction?
I would have thought that moving air lowers the pressure and thus the temperature too.
Brrrrrr...how cold does it get there? How windy?
The moving air itself has a pressure. Assuming a normal everyday fan, the differences in pressure between the static air and the moving air isn't noticeable to those who are enjoying the cool refreshing breeze.
Related to How does a fan cool your skin, exactly?
1. How does a fan create a cooling effect on the skin?
A fan cools the skin by using the process of convection. When a fan blows air onto the skin, it removes the warm air that surrounds our body and replaces it with cooler air. This creates a cooling sensation on the skin, making us feel more comfortable.
2. Does the speed of the fan affect its ability to cool the skin?
Yes, the speed of the fan does affect its ability to cool the skin. A higher fan speed means that more air is being moved, resulting in a stronger cooling effect on the skin. However, the temperature of the air being blown by the fan also plays a role in the cooling process.
3. What is the role of evaporation in the cooling process of a fan?
Evaporation plays a crucial role in the cooling effect of a fan. As the fan blows air onto the skin, it also helps to evaporate the moisture on our skin. This evaporation process removes heat from our body, resulting in a cooling sensation.
4. Can a fan cool the skin in hot and humid weather?
Yes, a fan can still cool the skin in hot and humid weather. However, the cooling effect may not be as significant as in dry weather. In humid conditions, the air already has a high moisture content, making it less effective in evaporating the moisture on our skin. However, the convection process of a fan can still provide a cooling sensation.
5. Can a fan cool the skin without actually lowering the room temperature?
Yes, a fan can cool the skin without actually lowering the room temperature. As mentioned before, a fan removes the warm air surrounding our body and replaces it with cooler air. This creates a cooling sensation on the skin, even if the room temperature remains the same. However, the overall temperature of the room may decrease over time if the fan is left on, as it helps to circulate the air and create a more comfortable environment.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Mechanical Engineering
  • Other Physics Topics
