How does a fluid behave inside of a spherical cavity?
In summary, the conversation revolves around a spherical cavity filled with water and air. The question is raised about what will happen to the flow of water and if it will create turbulence or increase in speed. It is also mentioned that if the cavity is closed and only allows water to enter, the air inside will be compressed as the cavity fills up. The conversation then shifts to discussing the scenario of the cavity being on the surface of the sea and the need for a complete problem description. The concept of an ideal fluid and the potential for infinite pressure is also brought up, along with the question of what causes the influx of water into the cavity.
Domenico94
130
Suppose you have a spherical cavity, with a flow of a fluid ( in particular water), entering it from one side. What will happen to this flow? Will it create turbulences? Will speed increase? Will eventual waves entering the cavity be reflected, so creating waves with bigger amplitude?
Suppose the cavity is closed and doesn't allow water to exit .Only to enter.
What's inside the cavity ? If there's air it will be compressed while th cavern fills up. You'll have to tell us some more details for this scenario to work it out ...
Suppose it is on the surface of the sea, for example. So, the lower part is filled with water. The upper part is filled with air.
Why do you bring in the sea ? Try to paint a complete picture and set up a complete problem description. We're not telepathic.
Ideal fluid ? 'Infinite pressure' allowed ? What causes the influx ?
Likes Chestermiller
Related to How does a fluid behave inside of a spherical cavity?
1. What is the Navier-Stokes equation and how does it relate to fluid behavior in a spherical cavity?
The Navier-Stokes equation is a set of partial differential equations that describe the motion of a fluid. It takes into account factors such as viscosity, pressure, and density to determine the velocity and pressure of a fluid. In the context of a spherical cavity, the Navier-Stokes equation can be used to model how the fluid flows and behaves within the cavity.
2. How does the shape of a spherical cavity affect the behavior of the fluid inside?
The shape of a spherical cavity can have a significant impact on the behavior of the fluid inside. In a spherical cavity, the fluid tends to move in circular patterns, known as vortices. The size and number of these vortices depend on the size and shape of the cavity, as well as the properties of the fluid itself.
3. How does the density of the fluid affect its behavior in a spherical cavity?
The density of a fluid can greatly influence its behavior inside a spherical cavity. A denser fluid will have a greater tendency to form vortices and circulate within the cavity. This can lead to more complex and turbulent flow patterns compared to a less dense fluid.
4. Can the behavior of a fluid in a spherical cavity be predicted accurately?
Predicting the behavior of a fluid inside a spherical cavity can be challenging due to the complex nature of fluid dynamics. However, with the use of computational fluid dynamics (CFD) and advanced mathematical models, it is possible to accurately predict the behavior of a fluid in a spherical cavity.
5. How does the velocity of the fluid affect its behavior in a spherical cavity?
The velocity of a fluid can have a significant impact on its behavior in a spherical cavity. A higher velocity can result in stronger and more turbulent flow patterns, while a lower velocity may result in more laminar flow. Additionally, the velocity of the fluid can affect the size and number of vortices formed within the cavity.
