How does a gamma ray get converted to visible light
In summary, the process of heat transfer from the Sun's core to the photosphere involves Compton scattering of photons off free electrons and ions, resulting in lower energy photons and thermal equilibrium between the two gases. As the temperature decreases towards the surface, the photon energy peak shifts to the visible region.
Clara Chung
304
In the process of heat transfer from core to photosphere, each gamma ray in the Sun's core is converted during scattering into several million visible light photons before escaping into space.----from Wikipedia
How does heat transfer related to scattering? Is it related to Raman scattering as the energy of gamma ray decreases?
Science news on Phys.org
It is primarily Compton scattering of the photons off the free electrons which are present. The electrons also scatter off the heavier ions and produce lower energy photons through bremsstrahlung. These processes happen a huge number of times until the electron gas and the photon gas are in thermal equilibrium. At each radius, the photons and the electrons are in thermal equilibrium, but as you progress out from the core of the sun to the photosphere, the temperature of the photon gas (and the electrons and ions) gets steadily lower until it is approximately 5000 K near the surface, where the photon energy peak is in the visible region.
Likes Clara Chung
Related to How does a gamma ray get converted to visible light
1. What is a gamma ray?
A gamma ray is a high-energy electromagnetic radiation that is emitted from the nucleus of an atom during radioactive decay or other nuclear reactions. It has the shortest wavelength and highest frequency on the electromagnetic spectrum.
2. How does a gamma ray get converted to visible light?
A gamma ray can be converted to visible light through a process called scintillation. This involves the absorption of the gamma ray by a scintillator material, which then produces a burst of visible light photons in response to the absorbed gamma ray.
3. What is a scintillator material?
A scintillator material is a substance that can convert high-energy radiation, such as gamma rays, into visible light. It is typically a crystalline solid or a liquid that contains atoms with high atomic numbers, such as cesium, iodine, or sodium, which can efficiently absorb gamma rays.
4. How is the visible light produced by a scintillator material detected?
The visible light produced by a scintillator material is detected by a detector, such as a photomultiplier tube or a semiconductor device. These detectors are sensitive to light and can convert the light energy into an electrical signal, which can then be amplified and measured.
5. What are the applications of converting gamma rays to visible light?
The conversion of gamma rays to visible light has many practical applications, such as in medical imaging, security and surveillance, and scientific research. It allows us to detect and measure the presence of high-energy radiation, which can provide valuable information about the properties and behaviors of matter and energy.
  • Astronomy and Astrophysics
