How does a process of a Raman transition break quantum entanglement?
In summary: Basically, if you measure the qubit state while it's in a high energy state, it will decay back to its ground state, breaking the entanglement between the qubit and the laser. Basically, if you measure the qubit state while it's in a high energy state, it will decay back to its ground state, breaking the entanglement between the qubit and the laser.
tade
721
I'm reading this article about quantum entanglement, and the author writes about a process in a Raman transition which would break the entanglement, and I'm interested about how it breaks the entanglement.
So the passage which I'm interested in begins with: "The answer is to do an operation that we would describe in words", and the author also writes: "otherwise leave it alone".
And so what I'm wondering is, if a particle happens to be "left alone", since its being "left alone", and not interacting with the laser at all, as the author describes it, why does this act still break the entanglement?
It is hard to know exactly what the author means because it is written with words rather than math. But the Raman transition is basically a measurement, as by monitoring whether a photon was absorbed or not, you have measured the state of the particle.
Likes Lord Jestocost
and so after the Raman measurement is done, does it break the correlation between Alice and Bob
Basically, yes.
DrClaude said:
Basically, yes.
oh i see, so something about it is different from the type of measurement which allows for correlations right
No. Any measurement will break entanglement. (More precisely, anything that involves decoherence will break entanglement; measurement involves decoherence.) And as @DrClaude said in post #2, the Raman transition involves a measurement.
Likes Twigg and vanhees71
Raman transitions are just one way to implement a spin flip on an ion qubit. Spin flips are a coherent process and do not break entanglement. As others have already said, it's measurement that breaks entanglement.
In a typical ion quantum computer, measurement is performed by fluorescence: you drive the qubit's ground (or excited) state to a short-lived higher energy state and see if any photons are spontaneously emitted. If you detect a photon, then the qubit state you probed (ground or excited) was populated prior to your measurement. In this case, decoherence arises from the fact that the spontaneous emission process is driven by the vacuum electromagnetic field.
Likes vanhees71
FAQ: How does a process of a Raman transition break quantum entanglement?
How does a Raman transition break quantum entanglement?
A Raman transition is a process in which a photon is absorbed and then re-emitted by a molecule, resulting in a change in the molecule's energy level. This process can break quantum entanglement between two particles by altering their quantum states and causing them to become disentangled.
Can quantum entanglement be broken by other methods besides a Raman transition?
Yes, there are other ways to break quantum entanglement, such as through decoherence or measurement. However, a Raman transition is a commonly used method in quantum optics experiments.
What is the significance of breaking quantum entanglement through a Raman transition?
Breaking quantum entanglement through a Raman transition can be useful in studying the properties of entangled particles and their interactions with their environment. It can also be used to manipulate and control the entanglement between particles.
Is breaking quantum entanglement through a Raman transition reversible?
In most cases, no. Once quantum entanglement is broken through a Raman transition, the particles will no longer be entangled. However, there are some techniques that can be used to re-entangle particles after a Raman transition has occurred.
Are there any potential applications of breaking quantum entanglement through a Raman transition?
Yes, there are potential applications in quantum computing, quantum communication, and quantum cryptography. By breaking and manipulating entanglement, scientists can better understand and utilize the unique properties of quantum particles.
