somitra
- 4
Hi all
I am a little disturbed by the above thought about transformation of quantum state(or it's discription) between different frames of references. The doubt can be translated for a two state system as follows:
Let an observer has decided about her(his) x, y & z directions. He now writes down the state of a spin half particle as:
c+f+ + c-f-
f+ & f- are the spin up and spin down states for the z direction.
suppose now he decides to turn his axes about the z axis clockwise by angle p. At this point everyone will tell you that the state vector now transforms to:
c+eipf+ + c-e-ipf-
Now my doubt is this. A physical system is represented by a vector in a hilbert space. Rotation of coordinate axes does not change the state of the system, so it should be represented by the same vector even after the rotation. Why should the representation of the same state differ in two different frames. Why should the state vector transform. It's expectation values should.
What I have been thinking is this: First of all we do not observe the state vector at all. It's a mathematical construct. When representing a system by a hilbert space, any other hilbert space isomorphic to it is as good. The observer(??) is free to pick any of these. The two vectors given above are connected by an automorphism(of rotation about z axis) on the system's hilbert space and both vectors may be made to represent the same state, i.e either observer can choose either of the two vectors to describe his state. By doing this the form of Sx, Sy , Sz is altered. Now vector spaces are abstract object. For them to be of any use we must represent them by using matrices. Is this representation by matrices of state vectors unique, after we have fixed the base states.
Am I right in asserting that a state vector is defined uniquely only upto an automorphism of the hilbert space(provided this automorphism is applied to all the state vectors), not just a phase difference. Does this automorphism alter the matrix representation(of vectors and operators). Also do any of these ideas follow from representation theory(I know very little of it).
c+f+ + c-f-
c+eipf+ + c-e-ipf-
