How does a single phase induction motor work with a non-constant power supply?
Single-phase induction motors operate with a non-constant power supply, leading to variations in mechanical power output. Unlike three-phase systems, which provide a more stable power delivery, single-phase systems exhibit a sinusoidal power factor that results in time-dependent torque and speed. The discussion highlights that while three-phase motors can achieve constant power at the shaft due to the smoothing effect of inductance, this does not imply constant electrical power in the same sense as DC systems. The conversation reflects a clarification of misconceptions regarding the nature of power in single-phase versus three-phase induction motors. Ultimately, the understanding of power dynamics in these motors is crucial for their effective application.
dhruv.tara
NOTE: This is not a homework problem.
This semester we dealt with AC motors both three phase and single phase.
Now I know that 3 phase system is associated with constant power and therefore a constant power is being fed into that motor (and hence converted into constant mechanical power)
However single phase system do not have a constant power. For unity pf load they'll get sin^2 term which is not constant. Then in those kind of motors is the mechanical power is also not constant? If that is the case shouldn't we get time dependent torque or speed or both?
Where did you get the idea that there is constant electrical power going into an induction motor? Am I misunderstanding something?
My course text mentions that 3 phase induction motor runs on constant electric power. It proofs it in sense that the power delivered to the motor in a 3 phase balanced system is constant..
That sounds like mumbo-jumbo to me.
3 phase power does look more constant than 1 phase but it's not constant like DC power. Maybe your text is talking about the torque @ the shaft of your motor. In this case, the power @ the motor shaft could be constant due to the inductance of the motor windings acting like capacitors. Basically the windings smooth out the ripple of 3 phase power.
3-phase does deliver constant power to a resistive load.
I am not quite sure now for an inductive load such as a motor, due to the above comments. I now stand corrected.
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
