How does a two open ended pipe resonate?
  • Thread starter iScience
  • Tags
    Pipe
In summary: Or maybe just leave it be? I see your point about not straying too far from the original post.)In summary, for a pipe with both ends closed, sound is reflected off of the other end and is able to produce a standing wave. For pipes with both ends open or one end open, the air inside the pipe can resonate if there is an antinode at the open end, which is physically possible. This is because of the change in acoustic impedance at the open end, causing reflection and constructive interference. However, the resonance is not as efficient as with closed-end pipes. To find more information on open-end air columns, one can use a search engine such as Google and be sure to check the credibility of the sources
iScience
466
For a pipe with both ends closed, with sound being produced from one end, sound is reflected off of the other end and is able to produce a standing wave, however, for pipes with both ends open or one end open, how can the air inside this pipe resonate? or is it not really there air inside that is resonating? is it the pipe itself that is resonating?
Look up open-end air columns.
it only tells me that there must be antinodes at the open ends it doesn't say why. i understand why there cannot be antinodes at the end of a closed end, but why does it have to be an antinode at an open end?
That is the whole point of resonance.
It does not have to be.
But it is physically possible.
And if there is something that comes close, it will be there.
...Whaaaaaaat?
can you put context behind everything you just said i did not follow..
Let's consider the the left-hand end of an open-ended tube oriented horizontally. Suppose that end were not an antinode. Then there are two possibilities:
1) The pressure a bit to the left, outside the tube, is even higher than the pressure at the end.
2) The pressure a bit to the right, farther into the tube, is higher than the pressure at the end.
#1 doesn't make a lot of sense; that would have the pressure outside of the tube, where it is free to expand up and down as well as sideways, higher than the pressure inside the tube where it can only expand sidewise.
#2 looks more plausible, but by the argument above the pressure just outside the tube cannot be higher than the pressure just inside the tube, so a higher-pressure region inside the tube will want to move to the left.
So #1 says that you can't have an antinode outside the tube; #2 says that the antinode nearest to the end of the tube but still inside the tube will want to move towards the end of the tube (antinodes deeper in the tube are being pressed from both sides so tend to stay put). Put them both together and you end up with the antinodes right at the end of the tube.
Likes 1 person
so basically the pressure is highest at the ends right?
You cannot have an antinode outside the tube because the pressure outside the tube radially degrades and so you cannot make a standing wave out of this. which means obviously that whatever standing waves that exist have to exist inside the tube. is this right? it seems rather obvious now but just wanted to check if this is the right line of reasoning
Yep - that's the right line of reasoning.
At each end of the pipe there is a change in acoustic impedance (in the pipe and in the open air). Wherever there is a change in impedance when a wave propagates, there will be some reflection. Sometimes there is a phase inversion and sometimes not. If the distance between the discontinuities in impedance (the ends) is the right value for constructive interference (waves travel in both directions and be 'in step'), there will be a build up of energy stored in the column. That is what resonance is.
The reflection of energy at a closed end is more efficient than at an open end, as it happens, and the resonance is not so good with open ended pipes as with closed pipes.
Where?
Did you consider an internet search engine?
What search engine does Physics forums suggest for physics explanations and advice?
PS...dont want to stray to far away from the original post !
Google works just fine for this, although as with any internet search you still have to separate out the good sites from the plausible-sounding crap.
Some wikipedia pages are good, some are awful. If you get into the habit of looking at the discussion page as well, you'll generally get a pretty decent sense of how trustworthy/mainstream a given page is. The references and external links on a wikipedia page are often more valuable than the page itself.
(I'm wondering if we shouldn't fork a new thread for this discussion)
You can imagine a short 'plug' of air in each end of the tube. Because the ends are open there is little restraint on these 'plugs' moving in and out. Their movement will send pressure variations along the tube from each end and here is where you have the essentials of resonance.
2 waves traveling towards each other (from each end of the tube)
The one condition that must be satisfied is that the (open) ends of the tubes are antinodes.
Look at Google images for open tube resonance for some great illustrations.
Hope this helps
The Hyperphysics pages are a good source of info on most topics. Pretty reliable stuff, too but not always a lot of chatty explanations. Wiki is usually ok on the basics. Check back with PF to confirm what you have understood is pukkah.
FAQ: How does a two open ended pipe resonate?
1. What is resonance in a two open ended pipe?
Resonance in a two open ended pipe is a phenomenon where the pipe is able to produce a strong and sustained sound when a specific frequency of air is blown into it. This frequency is known as the fundamental frequency of the pipe and is determined by the length of the pipe.
2. How does the length of the pipe affect its resonance?
The length of the pipe is directly related to the fundamental frequency at which it resonates. The longer the pipe, the lower the fundamental frequency and the deeper the sound produced. Conversely, a shorter pipe will have a higher fundamental frequency and produce a higher pitched sound.
3. What causes the resonance in a two open ended pipe?
The resonance in a two open ended pipe is caused by the reflection of sound waves at its open ends. When air is blown into the pipe, it creates sound waves that travel down the length of the pipe and are reflected back at the open ends. This creates a standing wave pattern, causing the pipe to vibrate at its natural frequency.
4. What factors can affect the resonance of a two open ended pipe?
The resonance of a two open ended pipe can be affected by several factors, such as the length and diameter of the pipe, as well as the temperature and humidity of the surrounding air. Changes in any of these factors can alter the fundamental frequency of the pipe and affect its resonance.
5. Can different materials be used to create a two open ended pipe with different resonant frequencies?
Yes, different materials can be used to create a two open ended pipe with different resonant frequencies. The density and elasticity of the material will determine the speed of sound within the pipe, which in turn affects the fundamental frequency. For example, a pipe made of wood will have a different resonant frequency than a pipe made of metal of the same size and shape.
