Why Do Vacuum Tubes in CRT TVs Get Hot Despite the Vacuum?
In summary: An ECF80 is a dual pentode-triode tube. The pentode section plate dissipation is rated at 170 volts x 10 mA = 1.7 watts. the triode section plate dissipation is rated at 100 volts x 14 mA = 1.4 watts, for a total of 3.1 watts. The heater is 6.3 volts x 430 mA = 2.7 watts, as pointed out above.
ISX
120
Old CRT tv's use vacuum tubes and they get hot, but how does the glass get hot when the inside is under a vacuum and therefore shouldn't transfer any heat?
Radiation is probably the biggest contributor. There is still a very small amount of gas in the tube.
Sunlight feels warm, right? Even after 93 million miles (150 million km) of vacuum.
Heat travels in three ways: conduction, convection, and radiation.
The heat from the hot, glowing filament is radiated outwards, just as the sun radiates infrared radiation, just as the heat from a bonfire reaches you hundreds of feet away.
The current passing through the tube also heats the cathode and anode. (Pass too much current through the tube and the anode will glow red ... *not* good for the life of the tube!)
Adding to what twang said, the cathode and anode are both physically attached to the tube, so you get conduction as well as radiation.
Dale is correct ... and to add another detail, some tubes will glow various colors when they're in operation because they have quite a bit of gas inside.
See here: http://thetubestore.com/blueglow.html
That gas will *also* carry heat to the glass envelope of the tube.
I hate to tell you this but vacuum tubes have an internal heater, additional to the business electrodes (anode and cathode). This is usually run at 6 or 12 volts and works on resistive heating.
Infrared doesn't pass through glass well (which is why glass is used in greenhouses), so the heat can only be transferred out via conduction at the glass surface, and the result is hot glass, even with a near vacuum inside. The purpose of the heater inside a vacuum tube is to provide a source of free electrons.
Also I had the impression that most of the older vacuum tubes operated around 100 volts or so.
The vacuum tube plate dissipation (plate voltage times plate current) is often greater than the heater (or filament) power dissipation. Most of this heat is radiated out to the glass and cooled by air convection.
Bob S
Good point, but typical lineup in valve equipment is 1 to 5 signal stages followed by output stage where this may well be true.
For example just looking at random in Ball
An ECF80
Heater wattage = 6.3 volts x 430 milliamps = 2.7 watts
Anode watts = 180 vols x 5 milliamps = 0.9 watts
The ECF80 is a dual pentode-triode tube. The pentode section plate dissipation is rated at 170 volts x 10 mA = 1.7 watts. the triode section plate dissipation is rated at 100 volts x 14 mA = 1.4 watts, for a total of 3.1 watts. The heater is 6.3 volts x 430 mA = 2.7 watts, as pointed out above..
Bob S
Related to Why Do Vacuum Tubes in CRT TVs Get Hot Despite the Vacuum?
1. What is a vacuum tube?
A vacuum tube, also known as a thermionic valve, is an electronic component that controls the flow of electrons in a circuit. It consists of a glass tube containing metal components and is used for amplification, switching, and rectification of electrical signals.
2. How does a vacuum tube get hot?
A vacuum tube gets hot through the process of thermionic emission. This occurs when a filament or cathode within the tube is heated, causing electrons to be released from its surface and creating a cloud of electrons around it. As the electrons move towards the anode, they collide with other molecules in the tube, generating heat.
3. Why does a vacuum tube need to get hot?
A vacuum tube needs to get hot in order to function properly. The heat allows for thermionic emission to occur, which is necessary for the tube to control the flow of electrons in a circuit. Without this heat, the tube would not be able to amplify or switch electrical signals.
4. How hot does a vacuum tube get?
The temperature of a vacuum tube varies depending on its design and purpose, but it typically ranges from 1500 to 2000 degrees Celsius. The exact temperature also depends on the current flowing through the tube and the type of filament or cathode used.
5. Are there any risks associated with a vacuum tube getting hot?
Yes, there are some risks associated with a vacuum tube getting hot. The high temperatures can cause the tube to degrade over time, shortening its lifespan. There is also a risk of electrical shock if proper precautions are not taken while handling a hot vacuum tube. It is important to follow safety guidelines and use protective equipment when working with vacuum tubes.
  • Other Physics Topics
  • DIY Projects
  • Materials and Chemical Engineering
  • General Engineering
