How does a variable rate inverter work in a Tesla car?
In summary, an induction motor's speed is limited by the frequency of the power it receives. To change their speed, Tesla uses a variable frequency inverter to create different frequencies.
bbbl67
212
So I recently learned that Teslas use AC induction motors rather than DC motors. Now I always assumed that DC motors would be easier to control the speeds of vs. induction motors, so it surprised me that they used an induction motor in the Teslas. Now in my old days I had heard that induction motors are limited to the speed at which their input power frequencies run at. So to change their speed, you need to change their input power frequency. I heard that they use a variable frequency inverter system to achieve the different frequencies.
Now from my understanding of inverters (limited), they produce a very square-wave AC pattern vs. a smooth sine wave AC pattern. The square wave is apparently not well liked by delicate electronics, but am I right in assuming that an electric motor wouldn't care if it's a square wave vs. a sine wave? If so, then the inverter probably doesn't have to be too sophisticated and need circuitry to convert the square into a sine wave?
Also how do they vary the frequency of the inverter?
When looking at 3 phase BLDC type motors ( like a real servo motor) you do often see a square wave pattern at lower power, that is probably where you have seen the Square wave, however they can also be driven with PWM Sine Wave, as are induction motor Variable Frequency Drives.
In a way you can think of a VFD as a synthesizer - allowing the controller to vary many aspects of the power fed to the motor - a basic inverter topology (circuit) can be used for ether square wave or PWM. Frequency, Voltage, and Rotation, can all be changed independently to drive the motor at the optimal operating point - and can be used to control dynamic braking - so bi-directional power flow. The most basic PWM method here is referred to and Volts per Hertz ( V/Hz) where the magnitude of the sine wave is proportional to the output frequency. Example a 480VAC 60Hz motor - will be run at 48V and 6 Hz... the current LIMIT ( max torque) is about the same across the operating range of the system.
The motor DOES "care" about the square wave, it is hard on the insulation (Voltage Spikes/ dV/dt) and generates harmonics (= losses) especially at higher currents and voltages, also square wave at high current is not good for any of the systems involved. So a good PWM (sine wave) is better for the motor and other systems, however it is less efficient for the inverter. The motor as an inductor - resists changes in current.
Likes bbbl67
So am I to assume that even a cheap modified sine wave inverter would be bad for the motor, as it's not a pure sine wave?
There are many factors that go into a commercal product, but you can build / modify an iinverter that would serve most purposes. In general the larger the motor the better an inverter you will want / need. In a Tesla - for example, the battery is the major investment, so many design desisions may put the care of the battery as one of the top considerations - ripple current, for example may be a major concern ( or not at all).
So "Bad for the motor" will have a number of factors - it used to be inverter grade motors to deal wiht the the affects of the VFD, but as the drives have gotten better you see this type motor less and less. (Also - the ability of the average motor to deal with the drives noise, has increased as well).
Building a 3 phase motor drive from scratch - is a pretty good project, if you have a good application ( e-vehicle for example.)
You might enjoy this introductory article . Even though it applies to locomotives not Tesla roadsters the basic principle is the same.
http://www.republiclocomotive.com/ac-traction-vs-dc-traction.html
And yes, motor designers are aware how non-sinewaves affect their motors and can design to handle those effects by better insulation and heat removal .
One of the effects most interesting to me was the phenomenon of "Shaft Currents".
Small currents flow along the length of the motor shaft and return through the frame . On its way through the bearings it eats them up by arcing.. Before VFD's it was problematic only in big motors more than about 400 hp .
When VFD's moved into household appliances they brought shaft currents along with them . The appliance industry quickly learned from the power industry to insulate the bearings.
So your humble washing machine motor "Ain't what it used to be" .
Try a search on "Inverter Duty Motors" .
old jim
Likes PhysicoRaj
I recently purchased an Electric stand up scooter. I do like the performance, but range is always an issue. So I started looking at what other scooter companies were doing about the range issue. RION, a company that makes the highest end e-scooters on the market, found that using a sine wave reduces battery consumption and increases motor efficiency by moving the peak of the wave, based on the current speed of the motor, to where it's most effective for power (torque). So perhaps if Tesla would take a closer look at the benefits of using a sine wave, they may increase the range of their vehicles without having to upsize their batteries.
Welcome to PF. :smile:
It's hard to believe that Tesla is not using the optimum drive scheme. Do you have any references to help this part of the discussion? Thanks.
Likes russ_watters
There is a lot of companies that HYPE new and novel motor drive schemes, but basically, a PWM Sinewave inverter, is used on all EVs whether they are Induction or BLDC. Certainly a cheap scooter could be using a BLDC with square wave, PWM Sine would help the motor efficiency.
Likes russ_watters and berkeman
I'll look at that, but I was asking for links to the Tesla systems that you thought were sub-par...
I was providing information that may help Teslas since the biggest complaint is Range. RION seems to be doing something new with the technology. Whether or not Tesla's technology is similar, I don't know. But if you look at the original post that talks about Tesla using a square wave, You'll see why I provided this information.
Some Tesla motors use synchronous reluctance motors (SYNRM), using BLDC variable frequency supply. They are very efficient because they have no rotor current, neither induced, nor applied, and thus no I2R losses in the rotor.. They also have good torque characteristics.
It is misleading to describe a BLDC drive as PWM.
If you have any idea that can improve the efficiency of Tesla's EVs significantly, run don't walk to the patent office.
Likes Vanadium 50 and berkeman
Well not necessarilly. Many of the sine wave generators for the three phase power are pulse width modulated at a much highr fequency to efficiently generate the envelope of the tyhree phase waves.
Is there any reason a three phase pure sine shape is the most efficient waveform for an arbitrary (meaning custom designed) brushless DC motor?. I wouldn't be surprised but know of no such constraint...of course motors seem a bit of a black art to me. I could also believe that a frequency dependent shapecould be made more effective.
This video will help. PWM switches on the same pair of wires. BLDC motor controllers change wire pairs with each switch. It is not trying to make sine waves.
I once worked with a EE on a four phase BLDC motor that used a trapezoidal waveform. He claimed that it gave more power than three phase with a sinusoidal waveform. I do know that those motors were 9.9" OD and 16" from front face to rear end bell, and were rated for 225 ft-lbs RMS torque and 600 ft-lbs peak torque at about 1500 RPM.
The trapezoidal waveform required more drive voltage because of the increased ##di/dt##. The DC buss ran at 650 volts nominal and about 800 volts peak after max regen.
Likes hutchphd
Related to How does a variable rate inverter work in a Tesla car?
1. How does a variable rate inverter work in a Tesla car?
A variable rate inverter in a Tesla car is responsible for converting the direct current (DC) from the battery into alternating current (AC) that is used to power the electric motor. This process involves using transistors to switch the direction of the current flow, which controls the speed and torque of the motor.
2. What is the purpose of a variable rate inverter in a Tesla car?
The variable rate inverter plays a crucial role in regulating the power output of the electric motor in a Tesla car. By adjusting the frequency and amplitude of the AC current produced, the inverter can control the speed and torque of the motor, allowing for efficient and smooth acceleration and deceleration.
3. How does a variable rate inverter affect the range of a Tesla car?
The variable rate inverter can impact the range of a Tesla car by controlling the power output to the electric motor. By optimizing the energy usage and reducing power loss, the inverter can help increase the overall range of the vehicle.
4. Is there a difference between a fixed rate inverter and a variable rate inverter?
Yes, there is a significant difference between a fixed rate inverter and a variable rate inverter. A fixed rate inverter has a predetermined output, while a variable rate inverter can vary the frequency and amplitude of the AC output, allowing for more precise control of the electric motor.
5. Are there any potential drawbacks to using a variable rate inverter in a Tesla car?
One potential drawback of using a variable rate inverter in a Tesla car is the cost. Due to the advanced technology and components required, variable rate inverters can be more expensive to produce and maintain. Additionally, there may be a learning curve for drivers to adjust to the different acceleration and deceleration patterns resulting from the variable rate inverter.
  • Electrical Engineering
