How does air resistance affect a ball's acceleration?
In summary: The direction changes as well, but that wasn't asked here.In summary, when a ball is thrown vertically upwards with an initial speed of v0 and experiences air resistance, the magnitude of its acceleration increases as it moves upwards. However, as the ball reaches its highest point, the acceleration decreases until it reaches its terminal velocity, where the acceleration becomes zero. This is due to the opposing forces of gravity and air resistance acting on the ball. The AP solution mentioned in the conversation may have misunderstood the question and compared the magnitudes of acceleration with and without air resistance, rather than considering the time-evolution of the acceleration.
Badgeray
A ball is thrown vertically upward with an initial speed of v0. It experiences a force of air resistance. The positive direction for all vector quantities is upward.
Does the magnitude of the acceleration of the ball increase, decrease, or remain the same as the ball moves upwards?
The magnitude of the ball’s acceleration with air resistance increases as the ball moves upwards because air resistance acts downwards, and the acceleration due to gravity also acts downwards. Acceleration becomes more negative, increasing the magnitude of the acceleration.
For example, if the acceleration due to gravity is -9.80m/s2 and the acceleration due to air resistance is -1.00m/s2, then:
Acceleration without air resistance = -9.80m/s2
Acceleration with air resistance = -9.80m/s2 + (-1.00m/s2) = -10.8m/s2
Comparing only the magnitudes of the accelerations:
Magnitude of acceleration without air resistance = 9.80m/s2
Magnitude of acceleration with air resistance = 10.8m/s2
The magnitude of the acceleration with air resistance is greater than the magnitude of the acceleration without air resistance.
However, the AP exam (question 1a) has the same question and this is their answer:
Question: http://apcentral.collegeboard.com/apc/public/repository/_ap05_frq_physics_c_m_45648.pdf
Solution: http://apcentral.collegeboard.com/apc/public/repository/_ap05_sg_physics_c_me_46691.pdf
Since velocity is upward, air resistance is downward, in the same direction as gravity. The velocity will decrease, causing the force of air resistance to decrease. Therefore, the net force and thus the total acceleration both decrease.
Which answer is right? Did the AP solution maybe forget that the question asked for magnitude?
You write that the acceleration will become more negative. Why so? What does drag depend on? Will drag increase as the ball rises?
That is a poor phrasing in the problem statement. You are not supposed to compare "acceleration with air resistance" with "acceleration without" (there your answer would be correct), the question asks for the time-evolution of the accelerating while the ball is moving upwards.
Likes Badgeray
As mfb points out, that is not the comparison they're asking you to make. As the ball continues its upward movement, will the magnitude of the acceleration stay at 10.8 m/s², will it decrease, or will it increase?
(I don't see poor phrasing, though).
Likes Badgeray
Thanks, I understand now. What about the downward part of the ball's path? Would acceleration increase?
At the highest point in the trajectory the speed is zero so the acceleration has a magnitude of g. After that, what happens as the speed increases? Hint, eventually a terminal velocity is reached and the acceleration is zero.
As you can see, it is possible to misinterpret the question. Some additional "over time" would have made it much clearer.
What do you expect?
Ah, so the acceleration decreases until it reaches its terminal velocity.
Its magnitude decreases, right.
FAQ: How does air resistance affect a ball's acceleration?
How does the surface area of a ball affect its air resistance?
The larger the surface area of a ball, the more air resistance it experiences. This is because a larger surface area means more air molecules come into contact with the ball, creating more drag.
Does the shape of a ball impact its air resistance?
Yes, the shape of a ball can greatly affect its air resistance. A streamlined shape, like a sphere, experiences less air resistance compared to a non-streamlined shape with edges and protrusions.
Is air resistance constant or does it change during a ball's motion?
Air resistance is not constant and can change during a ball's motion. As a ball accelerates, the force of air resistance will also increase. However, once the ball reaches a constant velocity, the force of air resistance will also reach a constant value.
How does air density impact a ball's air resistance?
The denser the air, the more air resistance a ball will experience. This is because there are more air molecules present to create drag on the ball. Air density can be affected by factors such as altitude and temperature.
Can air resistance affect the trajectory of a ball?
Yes, air resistance can affect the trajectory of a ball. As a ball moves through the air, it experiences a force in the opposite direction of its motion, causing it to slow down and potentially change direction. This is why balls with a lot of air resistance, like a beach ball, may not travel as far or as straight as a ball with less air resistance, like a golf ball.
