How does an index of refraction affect the EM field?
In summary: So changing the velocity, wavelength and all the functions of these quantities of the EM wave should be sufficient to get the equations of the EM wave in a material, is that correct?So changing the velocity, wavelength and all the functions of these quantities of the EM wave should be sufficient to get the equations of the EM wave in a material, is that correct?
2sin54
109
Hello. Say I have some refraction index n in a homogeneous material. Say I also have equations for the EM field (E and B vectors). Is it true to say that all that changes is the wavelength
[tex] \lambda \to \frac{\lambda_0}{n} [/tex]
and consequently the wave vector
[tex] k \to k_0 n ?[/tex]
Is it enough to account for this wavelength change to derive the EM field equations in a homogeneous material of refraction index n?
Science news on Phys.org
The equation of a one dimensional traveling wave is
2A/∂x2 = (1/v2)∂2A/∂t2
where v is the velocity of the wave.
Maxwell's wave equation is
2E/∂x2 = (εμ)2E/∂t2
Where ε and μ are the permittivity and permeability of the material respectively
recognizing that this is a traveling wave equation the velocity of the wave would be
v= 1/(εμ)½
in a vacuum v =c = 1/(ε0μ0)½
2E/∂x2 = (εμ)2E/∂t2
v= 1/(εμ)½
Thank you for the reply. Yes, the velocity changes and consequently both the wavelength and the wave number change as well. So changing the velocity, wavelength and all the functions of these quantities of the EM wave should be sufficient to get the equations of the EM wave in a material, is that correct?
I do not understand your question. The EM wave equation is derived directly for Maxwell's four equations. It relates the spatial variation to the time variation. The solution of the wave equation then provides the velocity. The wavelength and frequency are determined by the source of the wave not the wave equation itself.
Sorry for not being clear. I meant to say that I have the equations for the EM wave (in terms of E and B) in a vacuum (n = 1) and I wish to determine the equations for the same wave when it travels through a homogeneous medium (n != 1).
The only difference is that ε0μ0 is replaced by εμ for the particular medium you are interested in remember
μ = Kmμ0 Km = relative permeability
ε= Keε0 = Ke = dielectric constant.(relative permittivity )
Thank you. That more or less confirms my thoughts.
Related to How does an index of refraction affect the EM field?
1. What is an index of refraction?
An index of refraction is a measure of how much a material can bend or slow down light as it passes through it. It is represented by the symbol "n" and is different for each material.
2. How does the index of refraction affect the speed of light?
The higher the index of refraction, the slower the speed of light will be as it passes through a material. This is due to the increased bending of the light rays.
3. What impact does the index of refraction have on the direction of light?
The index of refraction determines the amount of bending that occurs when light passes through a material. A higher index of refraction means that the light will be bent more, while a lower index of refraction means less bending.
4. How does the index of refraction affect the intensity of light?
The index of refraction does not have a direct effect on the intensity of light. However, it does play a role in determining the amount of light that is transmitted or reflected as it passes through different materials.
5. Can the index of refraction change the wavelength of light?
Yes, the index of refraction can change the wavelength of light as it passes through a material. This is because the speed of light is slower in materials with a higher index of refraction, which can cause the wavelength to appear shorter. This phenomenon is known as dispersion.
