How does annealing improves the ohmic contact?
  • Thread starter madphdstudent
  • Tags
    Contact
In summary, the conversation discusses the effect of temperature on ohmic contacts between a p-type material and metal contacts, taking into account the work function of the metal and semiconductor. Annealing at higher temperatures can improve the contacts and make them ohmic, possibly by burning away oxide layers or forming metal-semiconductor phases. The specific material and contact types used can also play a role in the temperature dependence of the barrier potential.
madphdstudent
Suppose we have a p-type material and metal contacts deposited taking the work function of a metal and semiconductor into account. At room temperature (depending on the doping level) they might now show non-linear IV curve (non-ohmic behavior). How does annealing at higher temperature improves the ohmic contacts and eventually become ohmic? Is there a way to calculate at which temperature to expect the transition?
madphdstudent said:
Suppose we have a p-type material and metal contacts deposited taking the work function of a metal and semiconductor into account. At room temperature (depending on the doping level) they might now show linear IV curve (non-ohmic behavior). How does annealing at higher temperature improves the ohmic contacts and eventually become ohmic? Is there a way to calculate at which temperature to expect the transition?
Er... linear IV curve means that it is OHMIC!
Zz.
OK just made a typo.. Corrected.
Still question remains. What is the effect of temperature ?
This, I don't know, because it could easily depend on the type of contacts being used and the type of semiconductors. The only thing I can think of is that annealing burns away the oxide layer in between the metal and the semiconductor. Without knowing what kind of contact that was made and the material involved, this can only be a guess.
Zz.
Thanks for your reply zz. That definitely is true. Here materials does not matter here since I am asking the temperature dependence of the barrier potential right? Only numeric here would be work functions (work function of a metal> work function of the semiconductor) - meaning they should make it ohmic. But If that would help let's suppose that the contact metal is silver and semiconductor is p-type silicon. How does it become ohmic with temperature and how they remain ohmic is my question.
Anything that has been exposed to atmosphere will have adsorbed layers of adventitious carbon, water etc. on the surface which is typically insulating. By annealing after deposition you effectively remove some of this carbon (this is most obvious in an ultra-high vaccum.) The temperature is a function of the bond strength between the adsorbed species and the material.
Some ohmic contacts do rely on formation of metal-semiconductor phases (e.g. formation of Ni-Ga-O phase in case of Ni/Au contact on p-GaN). So it's important to identify the material you are interested in.
Related to How does annealing improves the ohmic contact?
1. What is annealing and how does it improve ohmic contact?
Annealing is a heat treatment process that involves heating a material to a specific temperature and then cooling it slowly. This process helps to remove defects and impurities in the material, allowing for better electrical conductivity and improved ohmic contact.
2. What types of materials can benefit from annealing for improved ohmic contact?
Annealing can be beneficial for various types of materials, including metals, semiconductors, and even polymers. It is commonly used in the production of electronic devices such as transistors and diodes, where ohmic contact is crucial for proper functioning.
3. How does annealing affect the surface of a material for improved ohmic contact?
During the annealing process, the high temperature causes the atoms on the surface of the material to diffuse, rearrange, and form new regions with enhanced electrical properties. This results in a smoother and more uniform surface, which improves the contact between the material and the electrode.
4. Is annealing the only way to improve ohmic contact?
No, there are other techniques that can be used to improve ohmic contact, such as surface cleaning, chemical treatments, and ion implantation. However, annealing is often the most effective method as it can improve the electrical properties of the entire material, rather than just the surface.
5. Are there any drawbacks to using annealing for improved ohmic contact?
One potential drawback of annealing is that it can alter the properties of the material, particularly its mechanical strength. This can be a concern for certain applications where the material needs to maintain its original properties. Additionally, annealing can be a time-consuming and expensive process, especially for large-scale production.
  • Materials and Chemical Engineering
  • Atomic and Condensed Matter
  • Electrical Engineering
