How Does Arcsinh Relate to Arccosh in Trigonometric Transformations?
  • MHB
  • Thread starter mathmari
Therefore, x=\arcosh\frac{1}{y}.In summary, We have that $s=\frac{\sqrt{1-y^2}}{y}$ and $x=\text{arcsinh} (s)=\text{arcsinh} \frac{\sqrt{1-y^2}}{y}$. According to the given information, we can deduce that $x=\text{arccosh} \frac{1}{y}$ by using the properties of hyperbolic functions and simplifying the expressions.
mathmari
MHB
5,049
Hey! :eek:
We have that $s=\frac{\sqrt{1-y^2}}{y}$ and $x=\text{arcsinh} (s)=\text{arcsinh} \frac{\sqrt{1-y^2}}{y}$. How can we simplify this?
According to my book it is $x=\text{arccosh} \frac{1}{y}$. How do we get that? (Wondering)
Mathematics news on Phys.org
mathmari said:
Hey! :eek:
Hey mathmari! (Smile)
We have:
$$\sinh x = s = \frac{\sqrt{1-y^2}}{y}$$
which is bijective.
Furthermore, we have:
$$\cosh^2 x - \sinh^2 x = 1$$
It follows that:
$$\cosh x= \sqrt{1+\sinh^2 x} = \frac{1}{|y|}$$
(Note that $\cosh$ is always positive.)
So that:
$$x = \pm\arcosh \frac{1}{|y|}$$
Checking the cases where $y$ is either positive or negative, we find:
$$x = \operatorname{sgn}(y)\arcosh \frac{1}{|y|}$$
(Mmm)
I see... (Nerd) We have the curve $$\left (\arsinh s-\frac{s}{\sqrt{s^2-1}}, \frac{1}{\sqrt{1+s^2}}\right ), s>0$$
If $(x,y)$ is a point of the curve then $$x=\arsinh s-\frac{s}{\sqrt{s^2-1}} \ \ \text{ and } \ \ y=\frac{1}{\sqrt{1+s^2}}.$$
We have that $$y=\frac{1}{\sqrt{1+s^2}} \Rightarrow \sqrt{1+s^2}=\frac{1}{y} \Rightarrow 1+s^2=\frac{1}{y^2} \Rightarrow s^2=\frac{1}{y^2}-1 \Rightarrow s=\pm \sqrt{\frac{1}{y^2}-1} \Rightarrow s=\pm \frac{\sqrt{1-y^2}}{|y|}$$
We set: $$w=\arsinh s \Rightarrow \sinh w = s = \pm \frac{\sqrt{1-y^2}}{|y|}$$
We have $$\cosh^2 w - \sinh^2 w = 1 \Rightarrow \cosh w= \sqrt{1+\sinh^2 w} = \frac{1}{|y|} \Rightarrow w = \pm\arcosh \frac{1}{|y|}$$
So we get $$x=\pm\arcosh \frac{1}{|y|}-\left (\pm \frac{\sqrt{1-y^2}}{|y|}\right )y$$
How do we get rid of the $\pm$ and the absolute value, since the result should be $$x=\arcosh \frac{1}{y}- \sqrt{1-y^2}$$ ? (Wondering)
Since we have taken $$y=\frac{1}{\sqrt{1+s^2}}$$ do we maybe assume that $y>0$ ? (Wondering)
Yep. (Nod)
Although rather than "assuming", we're "deducing". (Nerd)
Furthermore, in the problem statement it is given that $s>0$, so we can immediately pick a $+$ sign for $s$ as well.
I like Serena said:
Yep. (Nod)
Ok... Thank you very much! (Yes)
mathmari said:
Hey! :eek:
Note that \(\displaystyle \cosh^2(x)-1=\sinh^2(x),\cosh^2(x)=\sinh^2(x)+1\) and \(\displaystyle \cosh(x)+\sinh(x)=e^x\).
Then \(\displaystyle \arsinh(x)=\ln\left(x+\sqrt{x^2+1}\right)\) and \(\displaystyle \arcosh(x)=\ln\left(x+\sqrt{x^2-1}\right)\).
\(\displaystyle \arsinh\left(\frac{\sqrt{1-y^2}}{y}\right)=\ln\left(\frac{\sqrt{1-y^2}}{y}+\sqrt{\frac{1-y^2}{y^2}+1}\right)=\ln\left(\sqrt{\frac{1}{y^2}-1}+\frac{1}{|y|}\right)=\arcosh\frac{1}{|y|}\)
FAQ: How Does Arcsinh Relate to Arccosh in Trigonometric Transformations?
How is the arccosh function defined?
The arccosh function, also known as inverse hyperbolic cosine, is defined as the inverse function of the hyperbolic cosine function. It is denoted as arccosh(x) and is defined as the value y such that cosh(y) = x.
What is the range of values for the arccosh function?
The range of values for the arccosh function is all real numbers greater than or equal to 1. This is because the input for the hyperbolic cosine function must be greater than or equal to 1 for the inverse function to exist.
How do we evaluate the arccosh function?
The arccosh function can be evaluated using either a calculator or by using the identity arccosh(x) = ln(x + √(x^2 - 1)). This identity can be derived using the properties of inverse functions and the definition of the arccosh function.
What are the applications of the arccosh function in science?
The arccosh function has various applications in physics, engineering, and mathematics. It is often used to model exponential growth and decay in natural phenomena, such as population growth and radioactive decay. It is also used in solving differential equations involving hyperbolic functions.
Is the arccosh function the same as the inverse of the cosine function?
No, the arccosh function is not the same as the inverse of the cosine function. The inverse cosine function, also known as arccosine, has a different range and definition than the arccosh function. It is important to note the distinction between inverse trigonometric functions and inverse hyperbolic functions.
10K
9K
10K
