How does attenuation happen? Very confused
In summary: This is not the same as scattering, which involves a redirection of some of the light. Rather, attenuation describes the overall decrease in intensity of the light as it passes through a medium.
Clara Chung
304
How can light flux decrease after traveling in a medium without scattering it? Does attenuation mean scattering?
Also in Infrared spectroscopy, why does the intensity of light decrease when the molecule is vibrating in resonant frequency? Does the electron produce an E field opposite to the incoming E field of the EM wave so that they cancel out? How can we explain it in terms of the particle nature of light?
Absorption.
A molecule will absorb light with which it is resonant. Some of that light will be reemitted (the rest will eventually become thermal energy), but looking in the direction of the incoming light will show a great reduction in intensity. In most cases, you can treat the light as completely classical. The absorption by the molecule will correspond to the disappearance of one photon from the light field.
Likes Clara Chung
To supplement DrClaude's response, 'attenuation' can also refer to the process by which light (or sound) is scattered out of the initial propagation direction. Beer's law is an example of this.
Likes Clara Chung
Related to How does attenuation happen? Very confused
1. What is attenuation?
Attenuation refers to the reduction in intensity or strength of a signal as it travels through a medium, such as air, water, or a material.
2. How does attenuation occur?
Attenuation occurs when a signal encounters obstacles or interacts with the medium it is traveling through, causing some of the energy to be lost or absorbed.
3. What are the factors that contribute to attenuation?
The main factors that contribute to attenuation include distance, frequency, and the properties of the medium, such as its density, temperature, and composition.
4. Why is attenuation important in telecommunications and signal transmission?
Attenuation is important in telecommunications and signal transmission because it can significantly affect the quality and strength of the signal being transmitted, which can result in errors or interruptions in communication.
5. How can attenuation be reduced or prevented?
Attenuation can be reduced or prevented by using signal boosters or repeaters, utilizing frequency modulation techniques, or using materials with lower attenuation coefficients for signal transmission.
  • Other Physics Topics
