How does ball A come to rest and Ball B remain stationary?
  • Thread starter Richie Smash
  • Tags
    Ball Rest
In summary: Momentum and kinetic energy are conserved in an elastic collision, but momentum may not be conserved if friction makes it stop.
Richie Smash
293
In a collision between three identical steel balls A B C
A comes to rest and B remains stationary, while C rolls off.
In terms of the Forces acting, explain how Ball A came to rest and why Ball B remained stationary.
Well what I know here is that Ball A experiences the downward pull of gravity and also friction upon collision? Maybe that is why it stops.
I know that momentum is conseved and transfers through ball B but I can't think of the ''Forces acting here''
I do have the general idea of what's going on and that this collision is a good representation of an elastic collision where momentum and kinetic energy are conserved.
How can I represent this answer in a concise way without getting too complicated? Just the fundamental reasons
Give ball A some velocity and mass.
Ball B and ball C have the same mass but zero velocity.
Assume an elastic collision.
Conserving kinetic energy gives something like:
##\left(v^2_A m_A + v^2_Bm_B+v^2_Cm_C\right)_{pre}=\left(v^2_A m_A + v^2_Bm_B+v^2_Cm_C\right)_{post} ##
Since all the balls are the same weight, you can factor them out of the equation.
##\left(v^2_A + v^2_B+v^2_C\right)_{pre}=\left(v^2_A + v^2_B+v^2_C\right)_{post} ##
Also, you can use conservation of momentum to get:
##\left(v_A + v_B+v_C\right)_{pre}=\left(v_A + v_B+v_C\right)_{post} ##
It's not very clean to solve all three together, so imagine a tiny gap between balls B and C...work out the relation from A to B (ignoring ball C), then the new B to C.
https://en.wikipedia.org/wiki/Elastic_collision
Likes Richie Smash
You can't have it both ways. If friction makes it stop then KE will not be conserved.
Related to How does ball A come to rest and Ball B remain stationary?
1. How does the surface affect the motion of balls A and B?
The surface on which the balls are placed can greatly affect their motion. If the surface is smooth and frictionless, both balls will continue to move at a constant velocity unless acted upon by an external force. However, if the surface is rough or has a high coefficient of friction, the balls will slow down and eventually come to rest.
2. Why does ball A eventually come to rest?
Ball A comes to rest because of the force of friction acting on it. As it rolls on the surface, it experiences frictional force in the opposite direction of its motion, which eventually causes it to slow down and stop.
3. How does the mass of the balls affect their motion?
The mass of the balls does not directly affect their motion. According to Newton's first law of motion, an object will remain at rest or in motion with a constant velocity unless acted upon by an external force. Therefore, the mass of the balls does not play a role in their motion unless an external force, such as friction, acts on them.
4. Can other factors besides friction affect the motion of the balls?
Yes, other factors such as air resistance, the shape of the balls, and the angle at which they are placed can also affect their motion. Air resistance can slow down the balls, and the shape of the balls can determine how they roll on the surface. Additionally, the angle at which they are placed can affect the direction and speed of their motion.
5. Why does ball B remain stationary?
Ball B remains stationary because there is no external force acting on it to change its state of rest. It is not experiencing any friction or other forces, so it will stay at rest until acted upon by an external force.
