How does calculus relate to dimensions?
In summary: I appreciate your point about the important part to understand, but do you think that would be correct??I am trying to understand what time^2 and velocity^2 mean in terms of how to visualize them? )Appreciate any replies! :)In summary, time^2 and velocity^2 are related to how to visualize them scalar-wise. If you want an energy which is related to velocity, you need to use the dot product which is the square of the speed.
paulo84
112
1760b1620e8d07692ecfb879abb37fad5a34f238
82c6f8ceda1650271df82f27287811c32c629a68
I am trying to understand what time^2 and velocity^2 mean in terms of how to visualize them? This wasn't explained in Physics or Mechanics (Further Mathematics) in high school, unfortunately. It seems likely it relates to matrices, maybe?
For acceleration, you're better to think of it as metres per second per second rather than metres per second squared. For example: In freefall, your speed increases at a rate of 9.8 m/s per second. Mathematically, this is the same thing as 9.8 m/s2, but it's a little easier to wrap your head around.
Thanks. It's just... a square is a shape? Or not necessarily?
There isn't any way to "visualize" why there is a velocity squared term in the kinetic energy equation. Most equations in physics are in a mathematically simplified form that doesn't reveal the laws and principles that were used to derive them. Moral: Understanding how the equation is derived is more valuable than trying to "visualize" its individual terms.
Likes russ_watters
To square a number means to multiply a number by itself. It doesn't always refer to a geometric shape.
But isn't the number we get from squaring only known because of that shape? Or not?
OK...I'm visualizing hidden squares! Folded back on themselves...I appreciate your point about the important part to understand, but do you think that would be correct??
I am assuming that you know the difference between vectors and scalars. Energy is a scalar and velocity is a vector, so if you want an energy which is related to velocity then you need some operation which takes a vector and returns a scalar.
That operation is known as the dot product. So ##v^2## is shorthand for ##v \cdot v = v_x^2 + v_y^2 + v_z^2##. This is the square of the speed.
As far as visualization, it means that if the x-axis is speed and the y-axis is energy then the graph is a parabola with the vertex at the origin
Likes paulo84
Wow, thanks, that's awesome! Now I have some reading to do.
Look, there is no way to visualize what the equation is conveying in a physical sense. The mathematical visualization in terms of a graph is not important to the physicist.
Why? You can multiply 3 × 3 without involving geometry.
Oh sorry, I should have asked the question in the Maths subforum.
I wouldn’t go that far. If graphs and visualizations weren’t important to physicists then there wouldn’t be so many of them in physics papers and textbooks.
You're absolutely right
Dale - I came back to your post. So the vector velocity is the sum of the speed along each of x, y and z axes?
Relative to acceleration, is there an implication that you're dealing with 2 dimensions of time, or not?
Sorry, mixing up my concepts. The square of velocity is the sum of the square of the speed along each of x, y and z axes?
And likewise velocity is essentially speed in 3 dimensions, which can be expressed as a matrix?
Look my dude, you're overcomplicating this in your head. Let's start from the bottom. Position is where you are. The rate at which you change position is velocity. The rate at which you change velocity is acceleration. Change in position is distance per second. We can denote that as meters per second, or meters/seconds. Acceleration as the rate at which your velocity changes. This could be denoted as velocity per second, or velocity/seconds. If you sub in the definition of meters per second into that you get meters/(second^2).
I should also include that velocity has two components, speed and direction. Depending on the number of physical spatial dimension you are working with this, the direction part can have multiple components, one for every direction you're able to move in.
Thanks. I need to look at it in 3D to understand it! I was told in school I was a natural mathematician and a natural chemist but not a natural physicist. I only made it through the Mechanics paper because I could work out the inbetween maths, I sometimes have trouble grasping concepts which seem simple to others...
Jayalk97 said:
I should also include that velocity gas two components, speed and direction. Depending on the number of physical spatial dimension you are working with this, the direction part can have multiple components, one for every direction you're able to move in.
Tensors?
paulo84 said:
Tensors?
Not really quite sure what you mean by that but velocity is often represented as a vector, with a direction (where the arrow literally points) and the speed represented by magnitude (how long the arrow is). Sorry if I sound patronizing I don't really know where you are in your physics education so I want to spell everything out to make sure I'm clear.
You don't sound patronizing...https://www.physicsforums.com/threads/vectors-and-matrices.936357/
paulo84 said:
Good lol. But as for matrices, everything relates to matrices. They're just a way to display information. If you could find a way to put some set of information into a matrix, you could then easily manipulate that information to achieve a desired result. Matrices and linear algebra as a whole are used everywhere. For instance as an electrical engineering student I use them to solve for current and voltages in certain circuits. By storing the information I get from a circuit into a matrix I could often literally plug it all into a calculator and get answer that might take me 10 minutes of algebra otherwise.
The problem is it gets really really complicated when you have to put in inverse values into tensors and you can't just use '1's but have to work out the square root of everything. Well, maybe it's not that complicated?
Not my area of expertise haha. By the look of it you're taking some sort of solid mechanics class? If it doesn't require you to actively use linear algebra I'd just throw it all into a calculator and save time.
I meant cube roots. I'm not taking any class... :X
Are you familiar with vectors? This question looks like you have never used vectors.
If not, then this is absolutely priority number 1! Vectors are necessary for physics at all levels
Definitely not
Definitely not
I'm 33 and haven't dealt with vectors in maths since I was 17, unfortunately. Until very recently, that is...
My recommendation is to go back and review both vectors and basic differential and integral calculus. You can’t do any physics without vectors, you can do a little with just vectors and algebra, but most of what you are asking requires vectors and calculus too.
Definitely not
Can you tell me why 'definitely not'?
  • #31
It's just that you're thinking of units the wrong way. Honestly I would look at unit conversion lessons online usually in chemistry courses. Units don't need any sort of dimension attached to them.
  • #32
It is conceivable that @paulo84 is not aware of the distinction between "dimension" as in dimensional analysis and "dimension" as the number of items required in a basis for a vector space.
  • #33
I feel like you were taught or taught yourself certain things out of order @paulo84 . I would take a book out and linear algebra and read through it. It's very straightforward and interesting and it should also give you some clarification on how matrices work and, if it's a good textbook, how they are used in practice.
  • #34
I know that you claim to have trouble distinguishing clocks and rulers, but one of the defining things about rulers is that you can orient up to three of them orthogonal to each other and measure distances in orthogonal directions. There are not two orthogonal directions of time that you can measure with clocks.
  • #35
Yes, he is going out of order despite repeated suggestions by multiple people that it will not be an effective approach.
